05-06-2012, 08:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | For mstar imei change Must insert USB Insert sim Power on Select pc mode Install drivers Select com Write imei in boxes Click on write imei Click on run It will done |
05-06-2012, 11:31 | #4 (permalink) |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Process to do. 1:insert sim 2:insert battery 3:insert usb cable 4:select Modem or pc suite 5:install drivers C:\Program Files\Volcano Team\VolcanoBox\Drivers\Phone Drivers\Mstar 6:untick auto find 7:select modem port 8:tick on write imie 9:write imei 10:click on rum 11:run 12:it will be done |
05-06-2012, 11:56 | #6 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Try again......... Read this and try... SELECT MODEM OR PC SYNC.. ON PHONE SCREEN. CHECK IN DEVICE MANAGER FOR MSTAR USB CONNECTED PHONE COMPORT. REFRESH COMPORT AND SELECT SAME PORT FOR IMEI WRITING. if not done ..... Post result with error screen shot for more help.. |
05-06-2012, 12:17 | #7 (permalink) | |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
Oh!. STILL NOT SING PC SYNC MODE OR MODEM........USE THIS TRICK.. REMOVE USBCABLE AND CONNECT AGAIN. SWITCH ON PHONE IN NORMAL MODE, TYPE THIS CODE *#10# AND WAIT FOR FEW SECONDS.... THEN DO AS I SAID ON ABOVE POST..... | |
08-16-2014, 04:43 | #10 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 24 | imei for k9 For mstar imei change Must insert USB Insert sim Power on Select pc mode or modem Install drivers Select com untick auto detect pinouts Write imei in boxes Click on write imei Click on run It will done |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
