06-23-2013, 18:05 | #1 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 660421 Status: Offline Thanks Meter: 26 | Need Help, Flashing MT625A ERROR stuck on 60% (Solved) Read Flash working fine but got error on flashing it is stuck 60% i have 2 unit with the diffrent model and those normal before it's just for test USB mode flashing volcano v2.1.8 but now unit totally dead here is the log and screenshot : Volcano Updated: 2013-06-19 Connecting... Connection successful,connected state! Version: V3.8 SN:054-987-756 Port:COM9 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... D+ = 3, D- = 2 Detection D+/D- with 1.64 seconds. Continue to detect BOOT pin... New USB device: (VID_0E8D&PID_0003) BOOT(Pull Up) = 1 Detection completed. Setting pinouts... Find USB device:MTK USB Port (COM122), (VID_0E8D&PID_0003) Pinout setting complete. Available Ports:COM1 COM9 COM122 COM144 File versiHEXING50_COSMOS_11B_PCB01_gprs_MT6250_S00.I62 5M03_F10_L4_BT_FM_TV_V10.bin Searching for passwords... Could not find any potential passwords. [Privacy Lock]95101 [Privacy Lock]63133 Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CA01 Software version:0001 CPU TYPE:625A Internal version:8000 Boot downloading complete! Flash ID: 002C00CB Flash Type: SF_N25W128 Chip Capacity: 0x1000000(16MB) Baud adjust...complete. This detected file is not encrypted and it¡¯s safe to write data. >>Flash writing MTKFile3...63% trying back to Volcano v1.7.0 tick or untick USB Mode = same result with or witout battre = same result another way without Box only USB cable + BootKey = same result need suggestion or solution to fix this, whats wrong with my step on flashing progress Thank you br |
The Following User Says Thank You to madshark96 For This Useful Post: |
06-23-2013, 19:46 | #4 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Yes use buad rate to 230400 , problem will be solved tested solution |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
06-24-2013, 21:10 | #5 (permalink) | |
Member: 660421 Status: Offline Thanks Meter: 26 | Quote:
i use 230400 baudrate then 2unit now working as well here is the log and screenshot : 1st : 2nd : Need more longer time,.. it's Slowly but sure Great for the Teams !!! Hope this thread can be usefull for another users of volcano box Problem Solved br, madshark | |
06-24-2013, 23:14 | #6 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | yes in it slow took long time to write nearly 20-30 min but this flash id write good on this that buadrate hope you will enjoy the volcano |
