12-06-2012, 07:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Mardan, Pakistan
Member: 1803303 Status: Offline Thanks Meter: 24 | Qmobile E440 625A CPU password. (Solved) Qmobile e440 password problem when i go to detect tab and select mstar d+- after process set pinouts it found com port 4 but suddenly drivers misses and again it moves back to com 3. also tried with usb but usb drivers is not standing. what is the problem. |
12-06-2012, 07:11 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: kpk _PAK
Member: 1358184 Status: Offline Sonork: 100.1616912 Thanks Meter: 615 | before set pinouts mark after settings switches to platform and use latest volcano tool always best regards |
The Following User Says Thank You to aliyousafzai For This Useful Post: |
12-06-2012, 07:51 | #4 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Faisalabad Pakistan Age: 40
Member: 1562066 Status: Offline Sonork: 100.1622824 Thanks Meter: 555 | when u pinout setting complete then following the instruction from the picture |
The Following User Says Thank You to 6622622 For This Useful Post: |
12-06-2012, 08:59 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | @Amigo*mobiles After click on set pinout tick after Setting switches to platform now go back to mtk tab untick auto pinouts detect select operation you want (format. read flash. write flash. imei tools) and click run ( dont touch power button) try and post result. |
12-08-2012, 07:44 | #9 (permalink) |
Member: 1803303 Status: Offline Thanks Meter: 24 | Qmobile e440 succesful unlock Assalam o alaikum I have an E440 qmobile succesfully unlocked password. 1. untick auto detect 2. tick usb mode 3. click read flash 4. insert battery and press call buttons both and then insert usb 5. After reading flash 6. click analyse code 7. And the password is displayed in the picture. Thanks to Qaiser mehmood. |
