07-24-2014, 14:09 | #6 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2214243 Status: Offline Thanks Meter: 74 | good bhai kari ne joi lo thay jase Step 1 > Put double sim in phone on the set. Step 2 > After phone power on dial *#*#3646633#*#*. Step 3 > A menu will apper on screen , then select GPRS. Step 4 > To change imei 1 select 1ST PDP and input new imei and select ok. Step 5 > After this action order first select "Attached" second select "Reattached" and all will be done. P.s.if need to change second imei just follow the same steps , only the difference is on step 4 select 2ND PDP and that's it Thanks To all Gsm Friends Click Thanks Button |
The Following User Says Thank You to mahi_mobile For This Useful Post: |
