05-19-2014, 00:19 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | Si4904 problem I can t read flash (( SI4904)) LOG : Detection initiated, connect the phone and power on it... Vcc: null Gnd: null Analyzing Rx and Tx... SI4904 RX: 3, TX: 11 Continue to detect BOOT... SI4904 NBOOT: 7 Setting... Boot downloading...100% Boot downloading failed.Please check the port,or hold the Power on/off button and then re-operation! >>Error!Please hold the Power on/off button,select a corresponding flash type and try again. |
05-19-2014, 03:44 | #2 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | first detect pin outs on detect tab after set pins go back tab on which you want work untick mark auto detect pinouts then press run button and post result |
05-19-2014, 14:02 | #3 (permalink) |
Member: 510826 Status: Offline Thanks Meter: 183 | I know , read this please : SI4904 RX: 3, TX: 11 , Boot downloading...100% LOG : Detection initiated, connect the phone and power on it... Vcc: null Gnd: null Analyzing Rx and Tx... SI4904 RX: 3, TX: 11 Continue to detect BOOT... SI4904 NBOOT: 7 Setting... Boot downloading...100% Boot downloading failed.Please check the port,or hold the Power on/off button and then re-operation! >>Error!Please hold the Power on/off button,select a corresponding flash type and try again |
