Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 04-20-2014, 21:44   #1 (permalink)
akeal81's Avatar
Member: 1032123
Sonork: akeal81
Thanks Meter: 29
Mstar mw8533d not read
HELLO I GET PHONE WITH MSTAR MW8533D CPU HANG ON LOGO I TRY UNSUCCESSFULLY TO READ IT BEFORE TO FOR%AT I GET THIS SCREENSHOT PLEASE HELP ME TO SOLVE THIS PROBLEM
Old 04-21-2014, 04:33   #2 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
Try on default boot
AzimBahar
Old 04-21-2014, 05:10   #3 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
select default boot your problem will be solved
Qaisar Mahmood
Old 04-21-2014, 14:09   #4 (permalink)
akeal81's Avatar
Member: 1032123
Sonork: akeal81
Thanks Meter: 29
br
qaisar mahmood
still the same help me to solve this problrm
Old 04-21-2014, 14:47   #5 (permalink)
AniAxn's Avatar
Member: 1045758
Sonork: 100.1613661(Offline)
Thanks Meter: 4,307
@ akeal81 ....
Use Modify Cable .. http://forum.gsmhosting.com/vbb/9347474-post1.html
If you Use this Cable for Mstar Chip ..
No Need Any Power or Buttery ..
Just Plug the Cable ..
Or You Can use Also Volcano Main Cable ..
First Connect the Jig Correctly & Install Mstar Driver Properly ..
Use Default Boot No need to change Baud rate ..
Select Read/Write & Do Run ..
If you Get Any Error ...
Use Volcano low Version & Post Result ...
Br,
AniAXN
The Following User Says Thank You to AniAxn For This Useful Post:
Page generated in 0.13972 seconds with 8 queries
