Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 01-23-2015, 20:18   #1 (permalink)
Member: 2333782
Volcano Box Not Found
hi
The problem
Volcano Box Not Found. Please Connect Box and Run Software Again.
The work done
Clear All Box
Replacement windows
But the problem remains
Please Help
Old 01-24-2015, 05:33   #2 (permalink)
Member: 2082450
Thanks Meter: 1,454
Change USB cable.
Install proper driver for the box.
If u don't use external power for volcano box, then note the switch must be in off condition.
Don't use USB hub, e.g. Directly plug the USB cable to system...
Chandan
The Following 3 Users Say Thank You to chandanps18 For This Useful Post:
Old 01-24-2015, 06:21   #3 (permalink)
Member: 2333782
hi
All the work was done
The problem still exist
Old 01-24-2015, 06:39   #4 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Originally Posted by e30-851 View Post
hi
Hello delete Your Volcamo box drivers download this drivers install do restart
and post results.
Drivers - Download - 4shared
The Following User Says Thank You to TUN10 For This Useful Post:
Old 01-24-2015, 06:58   #5 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,428
Check Driver in device manager Also check usb cable .
Old 01-24-2015, 06:59   #6 (permalink)
Member: 2333782
Hello
Problems exist
Old 01-24-2015, 07:12   #7 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Hello
Problems exist
Do you have skype or sonorok give me details.
Old 01-24-2015, 07:21   #8 (permalink)
Member: 2279922
Sonork: 100.1662328
Thanks Meter: 2
I Think Akhtar Bhai please solve its problem online via Snooker / Team Viewer
The Following User Says Thank You to a1mobile882288 For This Useful Post:
Old 01-24-2015, 07:37   #9 (permalink)
Member: 2333782
Please Yahoo! ID ataeie 851
Old 01-24-2015, 09:23   #10 (permalink)
Member: 953334
Sonork: 100.1614005
CONTACT ME VIA SONORK
WHY YOU HAVE MADE SAME POST IN FLASH FiLE SECTION ?
ALWAYS POST SOFTWARE AND BOX PROBLEMS HERE IN VOLCANO BOX SECTION ,
AND FLASH FILE REQUEST IN FLASH FILE SECTION .
Old 01-24-2015, 09:36   #11 (permalink)
Member: 1983780
Thanks Meter: 353
1, first see ur volcano on off button
2, redownload the volcano update ur problem was solved... same problem with me few days ago.... try
Old 01-24-2015, 09:55   #12 (permalink)
Member: 2333782
hi
Please explain more
Old 01-24-2015, 17:01   #13 (permalink)
Member: 557473
Sonork: 100.1627500
Thanks Meter: 2,284
I think Its Detection Problem of PC Com Port
You must check it in other PC First
then tell report.
bR.
Old 01-25-2015, 06:44   #14 (permalink)
Member: 2333782
then tell report.
bR.
The problem exists in other systems
Old 01-25-2015, 07:03   #15 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 239
Hello how are you?download please ammy and give me id
Ammyy Admin - программа удаленного доступа к компьютеру, программа для удаленного управления компьютером - скачать.
Page generated in 0.20795 seconds with 8 queries
