Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Volcano Box
Old 11-18-2013, 15:54   #1 (permalink)
Member: 1386134
volcano box problem
Volcano Updated: 2013-02-26
Connecting...
Connection successful,connected state!
Version: V3.8
SN:120-535-571
Port:COM45
After format or Flash you have to press & hold power button for at least 1.30 mins.
Available Ports:COM1 COM3 COM4 COM45
Detection initiated, connect the phone and power on it...
Vcc: null
Gnd: 5
Analyzing Rx and Tx...
Some mobile phone must have VCC or GND pins set in order to detect pinouts. Detection requires a longer period of time, please be patient...
User stop
>>Pinouts are not fonud!
Old 11-18-2013, 16:24   #2 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 2,095
your mobile phone CPU Nama?
Old 11-18-2013, 20:09   #3 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
what cpu inside ???
sold rx tx then try
or find usb pin outs
Old 11-18-2013, 20:10   #4 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
try with this method
MTK USB Method
go to detect tab
select cpu type (D+ D-) MTK USB & Mstar (Do Find Boot)
connect phone
click detect button
then click on set pinout
now go back to mtk tab
untick auto pinouts detect
select operation you want (format. read flash. write flash. imei tools)
and click run ( dont touch power button)
try and post result with screen shot
Old 11-23-2013, 08:06   #5 (permalink)
Member: 1386134
Sir try x285 Connecting...
Version: V3.8
SN:120-535-571
Port:COM12
Note for win7 users :
Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
After that the spd drivers will have the ability to be loaded.
C:\VolcanoBox\PrtScn\PIC_2013_11_23_12_29_30_PM.jp g saved.
For many phones, charge pins need to be set in order to identify USB devices.
Detecting D+ and D-...
Vcc: null
Gnd: 5
Detection initiated...
Failed to detect.
Vcc: null
Gnd: 5
>>Failed to detect.but same problem
Old 11-23-2013, 08:22   #6 (permalink)
Member: 1494304
Sonork: 100.1606186
Thanks Meter: 108
full details bro?
unit name:
cpu?
unit problem
for us to easy to help about your inquery.
The Following User Says Thank You to warshock For This Useful Post:
Old 11-23-2013, 12:34   #7 (permalink)
Member: 1386134
i try to 10 mobile to format but no one is conneting to box these problem is coming plz help
Version: V3.8
SN:120-535-571
Port:COM16
Detecting rx and tx...
Vcc: null
Gnd: 5
User stop
Available Ports:COM1 COM16
Vcc: null
Gnd: 5
User stop
Vcc: null
Gnd: 5
Failed to detect.
Vcc: null
Gnd: 5
User stop
Vcc: null
Gnd: 5
User stop
Vcc: 9
Gnd: 2
User stop
Vcc: 9
Gnd: 2
User stop
Vcc: 9
Gnd: 2
Failed to detect.
Old 11-23-2013, 13:53   #8 (permalink)
ch mobiles's Avatar
Member: 748029
Sonork: 100.1603742
Thanks Meter: 1,822
did You Tried With Rx, Tx ??
Also Change Main Vcc/Grnd Cable.
open Volcano,Go To System > System Self Check & Click System Recovery.
B,R.
Old 01-23-2014, 12:05   #9 (permalink)
sadewophone's Avatar
Member: 1624056
Thanks Meter: 130
problem solved
http://forum.gsmhosting.com/vbb/f723...olved-1769355/
Old 05-26-2014, 17:49   #10 (permalink)
Member: 2193499
Sonork: love to all
VCC or GND pins
VCC or GND pins ka matlb or u kese set ho ge
Old 05-26-2014, 19:41   #11 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
if you did not know about vcc and gnd pins
then first lean about mobile repairing
then ask
Page generated in 0.18778 seconds with 8 queries
