06-24-2014, 17:26 | #1 (permalink) |
No Life Poster Join Date: Jan 2012
Member: 1713296 Status: Offline Thanks Meter: 67 | Why imei became invalid in mtk after reset Today just write flash file to q mobile A6, everything is ok but problem occurs as describe in subject, Same happened before with A9 in the past, Will support tell me why this is or it is a bug in setup. thanks |
06-25-2014, 11:57 | #4 (permalink) |
No Life Poster Join Date: Jul 2007 Location: India
Member: 557473 Status: Offline Sonork: 100.1627500 Thanks Meter: 2,284 | How to write IMEI..see below link - (Step-by-Step) http://forum.gsmhosting.com/vbb/f723...-step-1778848/ bR. Smk |
The Following User Says Thank You to Moiz Khan For This Useful Post: |
06-26-2014, 14:07 | #6 (permalink) | |
Member: 1713296 Status: Offline Thanks Meter: 67 | Quote:
I repaired imei according to this video with and without new methodand here are logs, Code: 4.Phone USB mode is enabled ================================== 1.Select the mobile's USB debugging. 2.Please input 15 bits of IMEI and click button Write IMEI. 3.When software shows Searching port,please power off mobile phone with battery inside and connect to box with cable. COM port searching and preloader handshake. Connect port COM44. COM port searching and preloader handshake. Connect successfully. CPU TYPE:MT6575 DSP Firmware Version: DSP Patch Version: Software Version:MAUI.11AMD.W11.50.SP.V19.P1 Hardware Version:TINNO15_ICS_HW Audio Version:Unknown IMEI1:354526050103973 IMEI2:354526055103978 Write IMEI failed. COM port searching and preloader handshake. Connect port COM44. COM port searching and preloader handshake. Connect successfully. CPU TYPE:MT6575 DSP Firmware Version: DSP Patch Version: Software Version:MAUI.11AMD.W11.50.SP.V19.P1 Hardware Version:TINNO15_ICS_HW Audio Version:Unknown IMEI1:354526050103973 IMEI2:354526055103978 Write IMEI failed. Connecting, Please Wait... Running data do not touch phone... Please Switch off device and switch on again?? Waiting for device to connect... Rechecking Imei Found Device...5FF6525EC0844B19 IMEI 1= Can't find service: iphonesubinfo IMEI 2= Can't find service: iphonesubinfo2 Write IMEI done, reboot please. >>================================== | |
06-26-2014, 15:04 | #7 (permalink) |
Freak Poster Join Date: May 2014 Location: In the Chip Level
Member: 2187058 Status: Offline Thanks Meter: 41 | Volcano is the best one. but, You also need GC PRO KEY. 1 Click IMEI CHANGING. http://forum.gsmhosting.com/vbb/f922/ and Repairing other device base bands also BR Micro Mind |
The Following User Says Thank You to Micro Mind For This Useful Post: |
