03-24-2014, 08:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | need help i am in trouble>>>> need flash file or solution. thanks. |
03-24-2014, 09:06 | #2 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: Heaven Age: 35
Member: 2141811 Status: Offline Thanks Meter: 38 | Flash Stock Rom using Qualfast Software Step 1: Download and install Android USB Drivers on your computer. In case Android Drivers are already installed on your Computer then skip this step. Step 2: Enable USB Debugging mode on your Android smartphone. To Enable USB Debugging: Setting > Developer Options > USB Debugging (Tick to enable it). Step 3: Power Off your Android Smartphone. Step 4: Now Enable AP Mode on your Android Smartphone. To Enable AP Mode: Press and Hold Power Key and Volume Up Key for 5-8 Seconds until AP Mode is enabled. Step 5: Now, Connect your Smartphone to the Computer using USB Cable. Step 6: Download the Stock Rom or Custom Rom that you want to Flash on your Android Smartphone and extract it on your Computer. Step 7: Download and Extract Qualfast Software on Your Computer. After Extracting you will be able to see the following files: Step 8: Now Open QUALFAST2.0.5.exe (you will find this from the extracted files in Step#7). Step 9: Once Qualfast Software is launched, Click on the Set Path Button from the Right. Step 10: Now, Locate the Rom Folder (that you have downloaded for your Smartphone in Step#6). Step 11: Once you have added the Rom correctly, the AP Path in the Qualfast Software will be set automatically and the Info Boxes will become Blue. Step 12: Now, Press on the OK Button to begin the Flashing Process. Step 13: Once Flashing Process is completed, you will be able to see Green Box. Step 14: Now, Close Qualfast Software on your Computer and Disconnect your Smartphone from the Computer. Step 15: Restart Your Smartphone. Quote:
