SmartSamBox SmartSamBox official support area |
04-30-2016, 04:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | j700f after write cert phone show no service on both sim Code: Welcome to Octoplus/Octopus Box Samsung software version 2.1.9 ----------------------------------------------------------------------------------- To connect SM-G925I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f_ 352843074615490_r28g8208kwd.cert Select Certificate2... Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f_ 352842074615492_r28g8208kwd.cert ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f_ 352843074615490_r28g8208kwd.cert Select Certificate2... Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J700F Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f- 353237072915813-r51gb1s9kbz.cert Select Certificate2... Selected file: C:\Users\salim\Desktop\cert\j700f\cert-sm-j700f- 353236072915815-r51gb1s9kbz.cert ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-J700F Firmware compiled date: Fri Apr 15 21:36:16 KST 2016 PDA version: J700FXXU2APD8 CSC version: J700FODD2APD4 SW version: J700FXXU2APD3 Phone SN: RZ8GC0JDWJT Android version: 5.1.1 (LMY48B) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-J700F-Unknown30-04-2016_15-29-39-.asec file Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
08-20-2016, 15:12 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ARG - AZUL
Member: 226845 Status: Offline Thanks Meter: 78 | blind #1 mutual, did not realize u were writing at smartsam, with an octoplus log! blind #2 srinibas, did not see itīs an octoplus log and answer as if it was an smartsamīs!! pay attention hehe |
08-20-2016, 23:07 | #8 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: Karachi
Member: 2564757 Status: Offline Sonork: 100.1673410 Thanks Meter: 27 | Quote:
08-28-2016, 03:21 | #9 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Double check First Post on correct Forum Place. Quote:
Although gone Box still Works And Check Blacklisted Status If all these does not work ask GSMSERVER Team for help at: Octopus/Octoplus - GSM-Forum dont forget to press thanks if helpfull | |
