03-10-2014, 20:42 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1067446 Status: Offline Thanks Meter: 0 | Can not unlock w205 the problem is that I´m trying to unlock se w205 and I´m getting this: Searching for SIMLock check...NOT FOUND The phone is locked after succesfull message. Can U help me? Thank U! |
07-09-2014, 10:34 | #3 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1535220 Status: Offline Thanks Meter: 2 | Same problem. 4SE - tool 2.0.3 (S/N:000000000614 V1.1) Selected model: W205 Selected operation: Desbloqueo Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Conexión establecida al puerto USB10 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:LOCOSTO Model:W205 IMEI:35809203-527826-1 AID:0002 Color:RED DEVICE_ID: 06018038C20086B80000000047720000 EROM: CXC1250616 R5A038 Enviando logic LOCOSTO: Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 0089/8904 (Intel) Chip: Intel 256 Mbit NOR (top boot) Logical address: 0x06000000 Size: 32 Mb OTP: LOCKED Reading TA security data...OK Autenticando con KEY KIDP96_S1_PRODUCTION_R1F...OK Searching for SIMLock check...NOT FOUND Resetting phone lock...OK Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [10 seg] |
07-09-2014, 10:45 | #4 (permalink) |
Member: 1535220 Status: Offline Thanks Meter: 2 | 4SE - tool 2.0.3 (S/N:000000000614 V1.1) Selected model: W205 Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 5-4-2010) Remove battery, wait a few seconds and insert it back Plug USB cable holding "C" button Conexión establecida al puerto USB10 You can now release the keys and allow the process to run. Do not disconnect the phone Identificando terminal...OK Chip:LOCOSTO Model:W205 IMEI:35809203-527826-1 AID:0002 Color:RED DEVICE_ID: 06018038C20086B80000000047720000 EROM: CXC1250616 R5A038 Enviando logic LOCOSTO: Firmware details: Software Id: 1223-5647 Software revision: R1CA001 Icon Id: 1223-5649 Icon Version: R1CA001 Language Id: 1223-5246 Language Version: R1CA001 CDA Id: 1234-8371 CDA version: R1A Enviando LoaderLIVE...OK Detectando tipo de flash...OK ID: 0089/8904 (Intel) Chip: Intel 256 Mbit NOR (top boot) Logical address: 0x06000000 Size: 32 Mb OTP: LOCKED S1_OTP_V1: ServKID:0078 ActKID:0048 ProdKID:0088 LoaderAID:0002 EROMAID:0001 SWAID:0001 CustAID:0001 SIMLockAID:0001 SIMlock details info coming soon Reading TA security data...OK Supported operations: Flasheo, Desbloqueo, TA, Dump flash, Phone lock reset Apagando terminal...OK Operation completed successfully. You can disconnect the phone now Proceso finalizado. Tiempo total [8 seg] |
