04-29-2014, 21:02 | #1 (permalink) |
No Life Poster Join Date: Sep 2010 Location: Gsm-Djibouti
Member: 1406357 Status: Offline Sonork: 100.1654421 Thanks Meter: 45 | E15i Unlocked Successfull with 4SE Selected model: Xperia™ X8 (E15) Selected operation: Read info Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:01268500-902347-8 AID:0001 Color:RED DEVICE_ID: 0F8C24108CCF040172B00557660019B3EB7979C3 EROM: 1229-3593 r8A029 Uploading logic MSM7227: Firmware details: Software Id: 1236-9291 Software revision: 2.1.1.C.0.0 FS Id: WORLD-1-8 FS version: 2.1.1.C.0.0 CDA Id: 1241-2655 CDA version: R4B Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED LoaderAID:0001 EROMAID:0001 SWAID:0001 CustAID:0001 SIMLockAID:0001 HWConfAID:0001 FUSES(0-3): 00774DFD 00040447 2004080F 67D50D65 SIMlock details info coming soon Reading TA security data...OK Supported operations: Flash, Unlock, Recovery, TA, Dump flash, Phone lock reset, Unlock by signature Shutting down device...OK Operation completed successfully. You can disconnect the phone now FINISHED [3sec] .................................. Selected model: Xperia™ X8 (E15) Selected operation: Unlock Selected interface: USB (EROM) Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011) Checking ADB drivers status...FAILED Install ADB drivers before starting Unlock operation Remove battery, wait a few seconds and insert it back Plug USB cable holding "Back" button Connected to USB3 You can now release the keys and allow the process to run. Do not disconnect the phone Device identification...OK Chip:MSM7227 Model:E15i IMEI:01268500-902347-8 AID:0001 Color:RED DEVICE_ID: 0F8C24108CCF040172B00557660019B3EB7979C3 EROM: 1229-3593 r8A029 Uploading logic MSM7227: Sending LoaderLIVE...OK Detecting flash type...OK ID: 20BC (ST) Chip: ST 4096 Mbit NAND (large page) Logical address: 0x08000000 Size: 528 Mb OTP: LOCKED Reading TA security data...OK Opening TA...OK Reading SIMLock data...OK Resetting phone lock...OK Original HwConf certificate detected Processing SIMLock signature...OK Opening TA...OK Writing SIMLock data...OK Disconnect USB cable, power on the phone and boot Android OS Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable Starting ADB server...OK(v1.0.31) Waiting for BX902FTYKW...OK Disabling security...OK Waiting for BX902FTYKW...OK Removing NAND restrictions...OK Waiting for BX902FTYKW...OK Disabling security...OK Waiting for BX902FTYKW...OK Installing required module...OK Writing S1boot image...OK Rebooting device...OK Operation completed successfully. You can disconnect the phone now FINISHED [517sec] |
