Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > 4SE
Old 10-09-2013, 13:20   #556 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
Thanks Meter: 221
Selected model: W302
Selected operation: Unlock
Selected interface: USB (EROM)
Checking USB driver status...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011)
Remove battery, wait a few seconds and insert it back
Plug USB cable holding "C" button
Connected to USB1
You can now release the keys and allow the process to run. Do not disconnect the phone
Device identification...OK
Chip:NEPTUNE Model:W302 IMEI:35653502-440134-6 AID:0002 Color:RED
DEVICE_ID: 120200102F030E140000000067280000
EROM: 1207-7713 R7A021
Uploading logic NEPTUNE:
Reading TA security data...OK
Authenticating with key KIDP96_S1_PRODUCTION_R1G...OK
Searching for SIMLock check...FOUND
Removing SIMlock...OK
Resetting phone lock...OK
Shutting down device...OK
Operation completed successfully. You can disconnect the phone now
FINISHED [18sec]
Old 10-10-2013, 10:03   #557 (permalink)
sana-ullah's Avatar
Member: 1724706
Sonork: 100.1622356
Thanks Meter: 63
4SE - tool 1.9.1 (S/N:00000000119D V1.1)
Selected model: T303
Selected operation: Phone lock reset
Connected to USB1
Chip:LOCOSTO Model:T303 IMEI:35778802-032139-3 AID:0002 Color:RED
DEVICE_ID: 0F023032C2006F6800000000434E0000
EROM: CXC1250616 R5A036
Uploading logic LOCOSTO:
Sending LoaderLIVE...OK
Detecting flash type...OK
Chip: Intel 256 Mbit NOR (top boot)
Logical address: 0x06000000
OTP: LOCKED
FINISHED [10sec]
Old 10-16-2013, 09:50   #558 (permalink)
FON-TECNO's Avatar
Member: 1201378
Sonork: 100.1594717
Thanks Meter: 303
4SE - tool 1.9.1
Selected model: W910
Selected operation: Desbloqueo
Selected interface: USB (BOOTROM)
Plug USB cable holding both "2" and "5" buttons
Conexión establecida al puerto USB1
Identificando terminal...OK
Enviando Preloader...OK
Enviando IDloader...OK
ChipSetB3150 Modelo:W910i IMEI:35832302-217526-3 CID:52 Dominio/Color:RED
OTP LOCKED:1 CID:52 PAF:1
Enviando logic DB3150:
Detectando tipo de flash...OK
Chip: ST 1024 Mbit NAND (large page)
Logical address: 0x80000000
Enviando CSLoader...OK
Autenticando con KEY KIDP96_EMP_DUMP_R1A...OK
Leyendo CLAVE UNICA del terminal...OK
CLAVE UNICA del dispositivo:90854508DF1CE36D2C67972440BF8BDD
Reiniciando terminal...OK
Enviando ResetLoader...OK
Autenticando con KEY KIDP96315035...OK
Reseteando a los valores de fábrica...OK
Enviando ProductionLoader...OK
Escribiendo SEMCBOOT...OK
Cambiando Certificado/CID a RED...OK
Recompilando área de seguridad...OK
Apagando terminal...OK
Proceso finalizado. Tiempo total [33 seg]
Old 10-16-2013, 10:36   #559 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Sonyericsson Xperia x10i remove pattern lock done
4SE - tool 1.8.9
Selected model: Xperia™ X10 mini (E10)
Plug USB cable holding "Back" button
Connected to USB3
        Chip:MSM7227 Model:E10i IMEI:01240300-011419-1 AID:0001 Color:RED
        DEVICE_ID: 5C395E01C6403126DC42291ABD0CE4005D2F3253
        EROM: 1229-3593 R8A029
Uploading logic MSM7227:
                Chip: ST 4096 Mbit NAND (large page)
                Logical address: 0x08000000
        OTP: LOCKED
FINISHED [3sec]
Old 10-16-2013, 10:37   #560 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
X10i mini unloked successfully
Checking ADB drivers status...OK
Connected to USB3
        OTP: LOCKED
        Opening TA...OK
Reading SIMLock data...OK
Original HwConf certificate detected
Processing SIMLock signature...OK
        Opening TA...OK
Writing SIMLock data...OK
Disconnect USB cable, power on the phone and boot Android OS
Enable USB Debug in Applications menu, make sure ADB drivers installed. Connect USB cable
Starting ADB server...OK(v1.0.29)
Waiting for CB511M2EQ9...OK
Disabling security...OK
Removing NAND restrictions...OK
Installing required module...OK
Writing S1boot image...OK
Rebooting device...OK
FINISHED [677sec]
Old 10-21-2013, 12:03   #561 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
E15i unlocked successfully..
Selected model: Xperia™ X8 (E15)
Connected to USB3
        Chip:MSM7227 Model:E15i IMEI:35845204-668905-6 AID:0001 Color:RED
        DEVICE_ID: BAB659B8274D55A04012C476BAFBA2BD4712700F
                Chip: Micron 4096 Mbit NAND (large page) x16
        OTP: LOCKED
        Opening TA...OK
        Opening TA...OK
Waiting for BX902N2CCC...OK
FINISHED [421sec]
Old 10-21-2013, 18:51   #562 (permalink)
Member: 1025102
Thanks Meter: 74
Sony Ericsson MT-11i 12w12 unlock ok
Old 10-22-2013, 14:21   #563 (permalink)
Member: 921094
Sonork: 100.1603246
Thanks Meter: 326
Lt26 patteren unlock done
4SE - tool 1.9.1
Selected model: Xperia™ S (LT26)
Checking USB driver status...FAILED (Device record missing)
Plug USB cable holding "Volume Down" button
Connected to USB3
Chip:MSM8x60 Model:LT26w IMEI:35337505-528075-3 AID:0001 Color:RED
DEVICE_ID: 03461104
EROM: 1247-3874 R10C008
Uploading logic MSM8x60:
OTP: LOCKED
FINISHED [5sec]
Old 10-31-2013, 11:06   #564 (permalink)
Member: 1647504
Thanks Meter: 236
SO-01B unlock OK
4SE - tool 1.9.1
Selected model: Xperia™ X10 (SO-01B)
Connected to USB9
Chip:QSD8250 Model:SO-01B IMEI:35949603-487074-8 AID:0001 Color:RED
DEVICE_ID: 2AB6C2F1B42B8A7D3738E91EEDC1B6A9C96C81C1
EROM: 1226-2253 R8A013
Uploading logic QSD8250:
Chip: Micron 8192 Mbit NAND (large page) x16
OTP: LOCKED
Opening TA...OK
Opening TA...OK
Waiting for CB511L83Z0...OK
FINISHED [119sec]
Old 11-01-2013, 11:00   #565 (permalink)
sana-ullah's Avatar
Member: 1724706
Sonork: 100.1622356
Thanks Meter: 63
K750 Successfuly Unlocked
Selected model: K750
Selected interface: UART (BOOTROM)
Connect cable and press "Power" button shortly
Connected to COM4
Sending Preloader...OK
Starting GDFS service...OK
Reading GDFS security data...OK
ChipB2010 Model:K750i IMEI:35255701-397479-8 CID:49 Domain:RED
OTP LOCKED:1 CID:49 PAF:1
Uploading logic DB2010:
Chip: ST Tyax 256 Mbit NOR (top boot)
Logical address: 0x44000000
Connected to COM4
Sending ResetLoader...OK
Authenticating with key KIDP96201233...OK
Reseting to factory defaults...OK
Connected to COM4
Sending ProductionLoader...OK
Writing EROM...OK
Changing certificate to A1_DB2010_49_RED...OK
FINISHED [73sec]
Old 11-02-2013, 11:32   #566 (permalink)
toky06's Avatar
Member: 196627
Sonork: 1608298
Thanks Meter: 6
Password google ok
Modello selezionato: Xperia™ U (ST25)
Operazione selezionata: Phone lock reset
Interfaccia selezionata: USB (EROM)
Verifica dello stato del driver USB...OK (SEMC Flash Device v3.0.0.0 | 11-25-2011)
Rimuovere la batteria, attendere alcuni secondi ed inserirlo nuovamente
Collegare il cavo USB tenendo premuto il tasto "Volume Down"
Connesso a USB1
Ora č possibile rilasciare i tasti e consentire il processo per l'esecuzione. Non scollegare il telefono
Identificazione del dispositivo...OK
Chip:STE U8500 Modello:ST25i IMEI:35445705-949503-0 AID:0001 Colore: RED
DEVICE_ID: E08DCFA59E31F581BB25DE1E9E2755A8E7D51F2D
EROM: 1240-4128 R10E013
Caricamento della logica STE U8500:
Invio di LoaderLIVE...OK
Rilevamento tipo di flash...OK
Dimensione: 7576 Mb
OTP: LOCKED
Leggere TA dati di sicurezza...OK
Spegnimento del dispositivo...OK
Operazione completata. Č possibile scollegare il telefono ora
FINITO [3sec]
Old 11-08-2013, 07:45   #567 (permalink)
Member: 1066865
Thanks Meter: 593
4SE - tool 1.9.0 (S/N:00000000042B V1.1)
Selected model: Xperia™ ray (ST18)
Remove battery. Link the TestPoint to GND and then plug USB cable
Connected to USB7
Connecting DLOAD...OK (PBL_DownloaderVER1.0)
Connected to USB7
Sending LoaderTEST...OK
Chip:MSM8x55 Model:ST18a IMEI:35834404-044462-2 AID:0001 Color:BROWN
DEVICE_ID: 2BA3C690D0D70243F78CFFE9DD61CB7B8B86E50E
Uploading logic MSM8x55:
ID: ECB3 (Samsung)
Chip: Samsung 8192 Mbit NAND (large page) x16
Logical address: 0x00000000
Logical block size: 0x40000
Logical blocks count: 0x1000
OTP: LOCKED
Opening TA...OK
Opening TA...OK
FINISHED [62sec]
Old 11-13-2013, 10:42   #568 (permalink)
Member: 1598559
i need this here. Plz hjhj
Old 11-13-2013, 11:53   #569 (permalink)
Registered User
Member: 685523
Sonork: 100.1603487
Thanks Meter: 381
c510 unlock secssses fully
4SE - tool 1.9.1 (S/N:0000000000C3 V1.1)
Selected model: C510
Checking USB driver status...OK (SEMC Flash Device v2.2.0.5 | 2-22-2011)
Connected to USB1
Sending IDloader...OK
ChipB3210 Model:C510 IMEI:35204503-957443-8 CID:52 Domain:RED
Uploading logic DB3210:
ID: ECAA (Samsung)
Chip: Samsung 2048 Mbit NAND (large page) x08
Sending CSLoader...OK
Authenticating with key KIDP96_EMP_DUMP_R1A...OK
Reading unique device key...OK
Device key:6996E747090AB0E1A538D27917E7E4C3
Restarting device...OK
Connected to USB1
Authenticating with key KIDP96321035...OK
Connected to USB1
Writing SEMCBOOT...OK
Changing certificate to RED...OK
Recompiling security area...OK
FINISHED [22sec]
Old 11-16-2013, 11:38   #570 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
My 1st experience with 4SE
Br - srinibas
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.37542 seconds with 10 queries
