Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 01-23-2012, 00:05   #1 (permalink)
Member: 534777
Thanks Meter: 214
9800 screen goes off when making or receiving
Hi All, please i have a strange problem with my bb 9800.
when i press the call button to make a call, the screen instantly goes off and comes on when the call ends though it goes through.
the same thing happens when i receive a call ie., press the call button.
have wiped and reloaded the os without any success.
your help is keenly waited.
thanx and best wishes
Old 01-23-2012, 00:57   #2 (permalink)
Member: 1391794
Thanks Meter: 54
just change the main flex cable and your good
Old 01-23-2012, 04:35   #3 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Proximity sensor not working Change main LCD flex as suggested above
Old 01-23-2012, 07:08   #4 (permalink)
Member: 1317658
Sonork: prakash cellular service
Thanks Meter: 441
Smile blackberry 9800 solution
Hi
This is Software problem just update latest firmware thats it tasted in Blackberry 9900 and after update dont restore backup
OFFICIAL: Torch 9800 Firmware 6.0.0.695 (App Version: 6.0.0.246)
if any issue post me reply
..:: X.R@M ::..
Old 01-24-2012, 09:17   #5 (permalink)
Member: 534777
Thanks Meter: 214
Originally Posted by x.ram View Post
Hi
..:: X.R@M ::..
updated with the link you provided but the problem still persists. any other suggestion apart from having to change the main flex cable???
best wishes
Old 01-24-2012, 09:26   #6 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
Thanks Meter: 238
just remove the protector and all will be ok
Old 01-24-2012, 14:06   #7 (permalink)
skyvind's Avatar
Member: 945459
Sonork: skyvind
Thanks Meter: 19
replace touch screen it ill work i also faced same pro bro.........
Old 01-25-2012, 16:24   #8 (permalink)
Member: 1391794
Thanks Meter: 54
best wishes
the sensor is on the main flex so there is no other way
Old 01-25-2012, 17:58   #9 (permalink)
Member: 164820
Sonork: phone@studio
Thanks Meter: 8
same with me. changed the flex still same story. without the back shell it works fine.i tink it has to do with the shell(casing)
Old 01-28-2012, 05:01   #10 (permalink)
Member: 534777
Thanks Meter: 214
which protector are you referring to please???
no clue what you are suggesting.
best wishes
Old 01-28-2012, 05:06   #11 (permalink)
Member: 534777
Thanks Meter: 214
Can you please show me where on the flex the proximity sensor is???
seen another suggestion it is a result of a too sensitive proximity sensor and that it should be shaded a bit.
any help will be appreciated.
best wishes
Old 01-28-2012, 05:11   #12 (permalink)
Member: 478046
Thanks Meter: 6
try to remove/replacec the earpiece of your phone.. tested many times...
Old 01-28-2012, 07:47   #13 (permalink)
Member: 619511
Thanks Meter: 53
change flex if not ok change battery
Old 01-28-2012, 19:01   #14 (permalink)
Member: 1548507
Sonork: 100.1603342
Thanks Meter: 2
light gone when making calls
just use only blue screws at the top of display back side , ur problem will be solved , or paste touch screen properly from up side
Old 01-29-2012, 07:57   #15 (permalink)
Member: 112087
Thanks Meter: 35
This pro lem comes out when you change black touch screen to white is it?
If yes you must programing to set up againg bettwen black and white....
GID1 for Germany D2 or Viag TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-21-1999 21:04
ORIGINAL SOFTWARE FOR SALE OR TRADE !!!!!!!!!!!!!!!!! andrew bennett Main Sales Section 1 07-27-1999 21:31
For Jefferson -6110 goes off itself sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-19-1999 21:28
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.24843 seconds with 9 queries
