07-18-2014, 07:37 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 74
Member: 1323797 Status: Offline Thanks Meter: 154 | Blackberry 9360 battery cross |
08-08-2014, 07:00 | #3 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2169954 Status: Offline Thanks Meter: 2 | Hello choclate, check the battery contact on the phone, that is the solution, u can see from the illustration above. |
The Following User Says Thank You to dgreg72 For This Useful Post: |
08-08-2014, 17:26 | #4 (permalink) |
Junior Member Join Date: Oct 2012 Location: Africa
Member: 1825090 Status: Offline Thanks Meter: 0 | Hi Exus, Please I need your help. I have two (2) blackberry 9360s with a faulty light sensor, how can I bypass the sensor so that the keypad light remains ON no matter the light intensity. |
08-08-2014, 17:44 | #5 (permalink) |
Member: 1825090 Status: Offline Thanks Meter: 0 | And also, how can I get lcd backlight jumper solution? The capacitor that I'm supposed to connect the jumper wire to does not give out the required voltage again. It is giving out about 1.2volts instead of the normal 13 volts. Please help me. The phone also doesn't charge well. It rejects chargers that other blakberrys of the same type won't reject. Please how can I get it to charge normally. |
