PB Tool for Smartphones Dongle Protected Solution for Smart Phones |
01-30-2013, 10:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: Sukabumi
Member: 1594457 Status: Offline Sonork: 100.1646470 Thanks Meter: 145 | How to set keyboard layout bb 9700 |
01-30-2013, 12:00 | #2 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1768459 Status: Offline Sonork: 1613455 Thanks Meter: 264 | it's easy to set azerty to qwerty with pbtool with PBtool is you can repair keypad QWERTY/QWERTZ/AZERTY Follow this step : 1. Press Check Connection tab 2. Press STP/Factory OS then Explorer will come, after that, choose the MFI file. 3. Click OPEN then please wait until process done 4. Go to tool tab and just press and choose Set QWERTY/QWERTZ/AZERTY button you wanna to set. 5. After step 4 DONE, Press Set Normal Mode Button Choose SFI file. SFI file must be the same version of the Device so the Data of user not delete. If u wanna upgrade or downgrade SFI must be change APP version too...if not same cant match 6. Wait until the process completed . Done! sure it will be hang like that cause u didnt write special file for first that's mean u need special file then write on device then press " Set qwerty " button! Br, |
02-01-2013, 15:29 | #5 (permalink) |
Member: 1594457 Status: Offline Sonork: 100.1646470 Thanks Meter: 145 | [QUOTE=pbtool;9150839]it's easy to set azerty to qwerty with pbtool with PBtool is you can repair keypad QWERTY/QWERTZ/AZERTY Follow this step : 1. Press Check Connection tab 2. Press STP/Factory OS then Explorer will come, after that, choose the MFI file. 3. Click OPEN then please wait until process done 4. Go to tool tab and just press and choose Set QWERTY/QWERTZ/AZERTY button you wanna to set. 5. After step 4 DONE, Press Set Normal Mode Button Choose SFI file. SFI file must be the same version of the Device so the Data of user not delete. If u wanna upgrade or downgrade SFI must be change APP version too...if not same cant match 6. Wait until the process completed . Done! sure it will be hang like that cause u didnt write special file for first that's mean u need special file then write on device then press " Set qwerty " button! waiting special file.......................... |
05-14-2013, 05:40 | #9 (permalink) | |
No Life Poster Join Date: Feb 2011
Member: 1519258 Status: Offline Thanks Meter: 243 | Quote:
go and check this thread http://forum.gsmhosting.com/vbb/f740...users-1536510/ Thx | |
