RESET LCD “free with PBTOOL" WITHOUT CHANGE OS & LOST DATA Here's a brief tutorial reset LCD / LCD Auto pbtool BlackBerry use "all operational less than two minutes" The files needed: ---------------------------- 1. LCD auto file [type according to the type of device], here 2. Prepare a "firmware" / SFI / kernel with the same version with the version of firmware on the device prior to the reset / auto LCD patch, here or in the file OS / firmware BB in our own pc ---> version and platform version of the device together with the the patch will auto lcd. 3. Pbtool with the latest version or the "oldest" can too. LCD Auto Files downloaded here User: pbtool Pass: pbtool ---------------- User: phoneblank Pass: phoneblank ------------------------ User: blackberry Pass: blackberry ---------------------- User: android Pass: android ------------------ User: iphone Pass: iphone Link support: BR, |
Step workmanship Reset / Auto LCD if you want the data is not lost and OS remain: A. Check version of "SFI / kernel" contained on the device, to ensure we have the same file. 2. Set to normal mode / patch SFI - with files from support auto lcd here, finish. 3. Set to normal mode / patch SFI - with the file "SFI / kernel" in accordance with the version before the patch, Done, lcd auto - with the version and data as well as 3rd party app is the same. Check the BB OS versions prior to the reset LCD https://dl.dropbox.com/u/76631149/lcd4-e.jpg And make sure you have the OS / Firmware versions of the same with the os on the device before the reset lcd.. https://dl.dropbox.com/u/76631149/lcd5-e.jpg Perform Reset LCD with insert / patch file Auto / Reset the LCD use the button "Set Normal Mode" ---> select the file Auto LCD ---> Open ... wait until the finish.. https://dl.dropbox.com/u/76631149/lcd6-e.jpg https://dl.dropbox.com/u/76631149/lcd7-e.jpg Process Auto / Reset the LCD finish. The next step Write / Flash with SFI / Kernel according to earlier versions before the Auto / Reset the LCD, "place" SFI / The kernel is the OS / Firmware BlackBerry https://dl.dropbox.com/u/76631149/lcd8-e.jpg Wait until the finish ---> done, with the BB as the initial conditions, data and OS remain. https://dl.dropbox.com/u/76631149/lcd9-e.jpg[/QUOTE] |
Auto / Reset the LCD 9300, done ... without losing the data and also without changing the OS. Auto / Reset the LCD 9530, done ... without losing the data and also without changing the OS. |
Auto / Reset the LCD 8520, done ... without losing the data and also without changing the OS.. Auto / Reset the LCD 9700, done ... without losing the data and also without changing the OS.. |
Tutorial AUTO LCD 8520 |
sir can brief the lcd reset benefit is it like the lcd of blackberry come with the ver such as 9700 with 111/004 is it like we can use 111 instead of 004 while using this reset option or so |
yes you can, if success dont forgot post the result |
what is meaning lcd rest?? we can change lcd like m1 whith m6?? |
Some type blackberry LCD serial number can not be used on the device. Therefore need to reset the LCD to be used in device. Means PBTOOL can converted it ! See carefully the video Best Regard! anttech |
holle It's can not rest lcd on my 9530? I tried many times, "auto LCD rest9530.sfi" pbtool 0.6 or 0.7 I have tried;it‘s fail;The software displays load done, but did not change; the "Auto lcd rest9530.sfi file is problems? who can help me? sorry my English:confused::confused::confused: |
There is a bug in some file. SFI as 9530, because of differences in hardware references on each device. because there is a tester that can successfully do a "reset lcd" in the above-mentioned types, such as sample video we upload. once again in this case we only help, this is not a feature. For features in pbtool "auto lcd" button function for to old security / mini-USB and the types that exist in support pbtool special file. Br, |
Sorry, you mean pbtool does not support the BlackBerry rest the lcd, is not it?I do not know that online video is from?http://forum.gsmhosting.com/ubb/confused.gifhttp://forum.gsmhosting.com/ubb/confused.gifhttp://forum.gsmhosting.com/ubb/confused.gifhttp://forum.gsmhosting.com/ubb/eek.gifhttp://forum.gsmhosting.com/ubb/eek.gifhttp://forum.gsmhosting.com/ubb/eek.gif |
Dear Friends, If you don't understand, Come to my sonork and let me teach you for understanding. Video Already Uploaded ! or you can go to support site and you can check which LCD Reset Supported by PBTOOL Best Regard ! anttech |
dear friend just add me dnt worry ill solve ur problem and ill guide u dnt worry 100.1591515 |
i am stuck after i press Set normal mode auto lcd 9700 1 and auto lcd 9700 2 as well .both not working ... Code: Set Device to Normal Mode (Upload SFI)... phone off but not booting back and the process start never ends. |
