Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > PB Tool for Smartphones
PB Tool for Smartphones Dongle Protected Solution for Smart Phones
Old 06-06-2012, 05:08   #1 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
RESET LCD “free with PBTOOL" WITHOUT CHANGE OS & LOST DATA
Here's a brief tutorial reset LCD / LCD Auto pbtool BlackBerry use "all operational less than two minutes"
The files needed:
1. LCD auto file [type according to the type of device], here
2. Prepare a "firmware" / SFI / kernel with the same version with the version of firmware on the device prior to the reset / auto LCD patch, here or in the file OS / firmware BB in our own pc ---> version and platform version of the device together with the the patch will auto lcd.
3. Pbtool with the latest version or the "oldest" can too.
LCD Auto Files downloaded here
User: pbtool
Pass: pbtool
User: phoneblank
Pass: phoneblank
User: blackberry
Pass: blackberry
User: android
Pass: android
User: iphone
Pass: iphone
Link support:
BR,
The Following 9 Users Say Thank You to mr.omphonx For This Useful Post:
Old 06-06-2012, 05:20   #2 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
Step workmanship Reset / Auto LCD if you want the data is not lost and OS remain:
A. Check version of "SFI / kernel" contained on the device, to ensure we have the same file.
2. Set to normal mode / patch SFI - with files from support auto lcd here, finish.
3. Set to normal mode / patch SFI - with the file "SFI / kernel" in accordance with the version before the patch, Done,
lcd auto - with the version and data as well as 3rd party app is the same.
Check the BB OS versions prior to the reset LCD
And make sure you have the OS / Firmware versions of the same with the os on the device before the reset lcd..
Perform Reset LCD with insert / patch file Auto / Reset the LCD
use the button "Set Normal Mode" ---> select the file Auto LCD ---> Open ...
wait until the finish..
Process Auto / Reset the LCD finish.
The next step Write / Flash with SFI / Kernel
according to earlier versions before the Auto / Reset the LCD,
"place" SFI / The kernel is the OS / Firmware BlackBerry
Wait until the finish ---> done, with the BB as the initial conditions, data and OS remain.
[/QUOTE]
The Following 2 Users Say Thank You to mr.omphonx For This Useful Post:
Old 06-06-2012, 05:22   #3 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
Auto / Reset the LCD 9300, done ... without losing the data and also without changing the OS.
http://www.youtube.com/watch?v=VdhKbcBmM3I
Auto / Reset the LCD 9530, done ... without losing the data and also without changing the OS.
http://www.youtube.com/watch?v=HmOlpoU2AF8
The Following User Says Thank You to mr.omphonx For This Useful Post:
Old 06-06-2012, 05:24   #4 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
Auto / Reset the LCD 8520, done ... without losing the data and also without changing the OS..
http://www.youtube.com/watch?v=OJlUFODoDGM
Auto / Reset the LCD 9700, done ... without losing the data and also without changing the OS..
http://www.youtube.com/watch?v=nRB75fzJFq8
Old 06-06-2012, 05:25   #5 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
Tutorial AUTO LCD 8520
http://www.youtube.com/watch?v=_OEKH-85fJM
Old 06-09-2012, 08:04   #6 (permalink)
Member: 776927
Thanks Meter: 18
sir can brief the lcd reset benefit
is it like the lcd of blackberry come with the ver
such as 9700 with 111/004
is it like we can use 111 instead of 004 while using this reset option or so
Old 06-09-2012, 09:02   #7 (permalink)
Member: 1519258
Thanks Meter: 243
yes you can, if success dont forgot post the result
Old 06-14-2012, 08:17   #8 (permalink)
Member: 1769097
Sonork: 1001597271
Thanks Meter: 35
what is meaning lcd rest??
we can change lcd like m1 whith m6??
Old 06-14-2012, 08:59   #9 (permalink)
anttech's Avatar
Member: 1768456
Sonork: 1613455
Thanks Meter: 1,542
Some type blackberry LCD serial number can not be used on the device.
Therefore need to reset the LCD to be used in device. Means PBTOOL can converted it !
See carefully the video
Best Regard!
anttech
The Following 2 Users Say Thank You to anttech For This Useful Post:
Old 06-15-2012, 15:28   #10 (permalink)
Member: 1772381
Sonork: 100.1617871
holle
It's can not rest lcd on my 9530? I tried many times, "auto LCD rest9530.sfi"
pbtool 0.6 or 0.7 I have tried;it‘s fail;The software displays load done, but did not change;
the "Auto lcd rest9530.sfi file is problems? who can help me?
sorry my English
Old 06-16-2012, 03:31   #11 (permalink)
pbtool's Avatar
Member: 1768459
Sonork: 1613455
Thanks Meter: 264
Originally Posted by wen2wen88 View Post
holle
sorry my English
There is a bug in some file. SFI as 9530, because of differences in hardware references on each device.
because there is a tester that can successfully do a "reset lcd" in the above-mentioned types, such as sample video we upload.
once again in this case we only help, this is not a feature.
For features in pbtool "auto lcd" button function for to old security / mini-USB and the types that exist in support pbtool special file.
Br,
The Following User Says Thank You to pbtool For This Useful Post:
Old 06-16-2012, 16:48   #12 (permalink)
Member: 1772381
Sonork: 100.1617871
Br,
Sorry, you mean pbtool does not support the BlackBerry rest the lcd, is not it?I do not know that online video is from?
Old 06-16-2012, 18:55   #13 (permalink)
anttech's Avatar
Member: 1768456
Sonork: 1613455
Thanks Meter: 1,542
Dear Friends,
If you don't understand, Come to my sonork and let me teach you for understanding.
Video Already Uploaded ! or you can go to support site and you can check which LCD Reset Supported by PBTOOL
Best Regard !
anttech
Old 06-17-2012, 06:46   #14 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 785
dear friend just add me dnt worry ill solve ur problem and ill guide u dnt worry
100.1591515
Old 06-17-2012, 13:21   #15 (permalink)
Member: 55800
Thanks Meter: 9
i am stuck after i press Set normal mode auto lcd 9700 1 and auto lcd 9700 2 as well .both not working ...
Set Device to Normal Mode (Upload SFI)...
Selected File: D:\PBtool\Auto LCD 9700_2\Auto LCD 9700.sfi
Process Start...
phone off but not booting back and the process start never ends.
The Following User Says Thank You to kit_kit For This Useful Post:
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-24-1999 05:45
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.25722 seconds with 10 queries
