08-18-2013, 03:17 | #1 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Piranhabox - Alcatel One Touch 918N Hang Logo Easy Solved And Firmware readflash procedure connect piranhabox to laptop usb open piranhabox software cable name? select usb(usb&mode) click usbmode click onekey root select 8th boot(MT65xx) click start bootkey press vol- plus power on wait to done root Code: Waiting for USB Port... Set MTK USB Port (COM18) Please Hold "ON" to connect with the phone... Unstable usb port, maybe not set discharge pin Waiting for USB Port... Set MTK USB Port (COM18) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6573 Ver: CA01 Loading Bootloader 8 Nand Flash Type: [TOSHIBA] TC58NYG0S8C Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading ROOT DATA...500000_600000 D:\PiranhaBox\piranha-box installer\Piranha_box_V1.30\MTK6573nandboot1308180942.img Waiting for USB Port... Set MediaTek DA USB VCOM Port (COM146) Writing ROOT DATA...500000_600000 Root OK. total£º 1 mins11 s click androidtool select cablename usb(usb&mode click usb mode click info then click start click wipe then click start logs here Code: Connecting to Phone,Wait..ok Hardware:mt6573 Board:one_touch_918N_SPPH CPU ABI:armeabi Manufacturer:TCT Model:ALCATEL ONE TOUCH 918N Android Ver:2.3.6 bootloader ver:unknown User:zxliu Baseband ver:6573 Build number:ALPS.GB.JRD2.SP.V2 IMEI1: Root: Rooted Done Connecting to Phone,Wait..ok Wipe data... Done Quote:
br: ernie78 piranhabox team Last edited by ernie78™; 08-18-2013 at 06:34. Reason: add bootkey message and readflash logs | |
The Following 5 Users Say Thank You to ernie78™ For This Useful Post: |
08-19-2013, 17:03 | #2 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1791089 Status: Offline Sonork: 100.1619289 Thanks Meter: 886 | Yes many Original Other Branded Phones Also Supported Before Do anything ., Read Flash backup We dont always shout each & every Small things as World First We work Best for Our Software performance Regards Piranha's |
The Following User Says Thank You to Piranhabox For This Useful Post: |
01-13-2014, 17:44 | #5 (permalink) | |
Insane Poster Join Date: May 2012
Member: 1757500 Status: Offline Thanks Meter: 27 | Quote:
Waiting for USB Port... Set MTK USB Port (COM226) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6573 Ver: CA01 Loading Bootloader 8 Nand Flash Type: [TOSHIBA] TC58NYG0S8C Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x21000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Reading ROOT DATA...500000_600000 G:\GSM ALL\piranhabox\Software\Piranha_box_V1.30(1)\Piran ha_box_V1.30\MTK6573nandboot1401132204.img Waiting for USB Port... Set MediaTek DA USB VCOM Port (COM282) Writing ROOT DATA...500000_600000 Root OK. total£º 1 mins24 s | |
