09-22-2012, 12:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Riyadh (KSA)
Member: 452214 Status: Offline Sonork: No warranty Thanks Meter: 394 | Samsung I9300 SPD CPU 6530A Done Piranha BOX [TEST REPORT] READ FLASH WRITE FLASH FORMAT Enjoy using Piranha box: More NEW CPU TYPE Comming for test............ br YOU |
The Following 6 Users Say Thank You to boy_muslim For This Useful Post: |
10-08-2012, 17:27 | #6 (permalink) |
Freak Poster Join Date: Dec 2011 Location: india
Member: 1701545 Status: Offline Thanks Meter: 100 | i9300 i9300 this version (i9300 spd 6800 6530A_GD27LQ64 ) i read succese flash n i write restart set flash write done but set is dead i thing version is some but why set is dead pls tell me or any other flash file post here n not conet this set proper D+:3 D-:2 Gnd:5 Spread Pinout Setting Ok. Searching USB to Serial Port... None SU2Serial Port. |
10-09-2012, 00:51 | #7 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
press home+vol up+pwer on button to fast ditection br: ernie78 piranhabox team | |
10-09-2012, 16:45 | #9 (permalink) |
Member: 1701545 Status: Offline Thanks Meter: 100 | i need i9300 flash file i9300 flash 6530A_GD27LQ128 16mb i flash this version set is not on my handset version is some why not set is on pls tell me product supporter Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot10... CPU type: 6530A Flash type: NOR Formating... Format Completed. or any other solution pls help me sir thanks |
10-10-2012, 03:25 | #10 (permalink) | |
see this my post that is 16mb firmware>>> click inside br: ernie78™ piranhabox team | |
The Following User Says Thank You to ernie78™ For This Useful Post: |
10-10-2012, 08:14 | #11 (permalink) |
Member: 1701545 Status: Offline Thanks Meter: 100 | i9300 flash done but set is not on sir thanks for file but not match this version pls pls other file post |
The Following User Says Thank You to dineshd For This Useful Post: |
10-10-2012, 10:40 | #12 (permalink) | |
for fast solved im try to searching that fone firmware to the market br: ernie78™ piranhabox team Last edited by ernie78™; 10-10-2012 at 10:46. | |
10-10-2012, 12:50 | #14 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | to change imei click repaired imei use scanusb then click start hold home+vol up+power on button post screenshot for fast solved br; ernie78™ piranhabox team |
10-10-2012, 18:43 | #15 (permalink) |
Member: 1701545 Status: Offline Thanks Meter: 100 | i 9300 test mode ok but imei fail Scaning SPD Pinouts,Connect the phone and Power On it .#.. Connection Error,Please Check Cable bad. Sensing Failed Scaning SPD Pinouts,Connect the phone and Power On it .#.. Connection Error,Please Check Cable bad. Sensing Failed Scaning SPD Pinouts,Connect the phone and Power On it .#..... D+:4 D-:3 Gnd:7 Spread Pinout Setting Ok. Searching USB to Serial Port... SU2Serial Port: COM110 Entering test mode,Please wait... Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu Test mode,OK RePairing IMEI,Please wait... RePair Failure Last edited by dineshd; 10-10-2012 at 18:48. |
