Old 02-24-2014, 17:28   #961 (permalink)
bakar_siddeik81's Avatar
Member: 1386392
Sonork: 100.1652322 QQ-3328190046
Thanks Meter: 604
symphony Android w60 Root and Gmail Reset Done.
Hardware:mt6575
Board:s8072
CPU ABI:armeabi-v7a
Manufacturer:symphony
Model:W60
Android Ver:4.0.4
bootloader ver:unknown
USB config:mass_storage,adb
User:Symphony_W60
Baseband ver:
Build number:ALPS.ICS.MP.V2.12
IMEI1:
Root: Rooted
Done
Connecting to Phone,Wait..
Connecting to Phone,Wait..ok
Reset Gmail...
Done.
The Following User Says Thank You to bakar_siddeik81 For This Useful Post:
Old 02-24-2014, 17:33   #962 (permalink)
Member: 1386392
Thanks Meter: 604
symphony Android w15 Wiping data Reset Done
Starting..
Searching Phone ...( Found )
Reading Info...
version: 1.0
product:
serialno:
cid:
Wiping all : ok
You can Restart Phone Now..
All Done..
Old 02-25-2014, 18:13   #963 (permalink)
zulfqarali's Avatar
Member: 1273573
Sonork: 100.1623251 QQ.2905713135
Thanks Meter: 3,779
World The First miracle 6589..6583 read flash fle+ imei repair
World The First miracle eagle eye
Q Mobile A700 read flash file & imei repair
read flash
reset gmail
imei null
imei repair done
[/CENTER][/QUOTE]
JAMILMOBILE OKARA
The Following 3 Users Say Thank You to zulfqarali For This Useful Post:
Old 02-27-2014, 09:03   #964 (permalink)
Member: 1386392
Thanks Meter: 604
Maximus-M315m Read And Format ok
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6260_S0000 Ver: CA00 md:8000
Downloading Boot7 ...
Nor Flash Code: 00EF0060(00180000)
Nor/SF Flash Size: 0x1000000 Hex Bytes
INT/EXT RAM Size: 0x0+0x0
Reading(Nor)...
The phone information:
HONGYU60A_11B_PCB01_GPRS_MT6260_S00.C280G1_HL01_H2 80H_MAX_130820.BIN
the file not be encrypted
Read OK.
Total time: 1 mins 3 s
File Save to: C:\Documents and Settings\bakar\Desktop\HONGYU60A_11B_PCB01_GPRS_MT 6260_S00.C280G1_HL01_H280H_MAX_130820.BIN
Definition Applied
Waiting for USB Port...
Set USB Modem Driver (COM42)
Unstable USB port
Definition Applied
Connected to Phone.
CPU: MT6260 Ver: CA00 SW:0000
Test Mode, Reading Information From the Phone...
Formatting as a safe mode
>>OK ! (items= 30)
Old 03-03-2014, 09:48   #965 (permalink)
zulfqarali's Avatar
Member: 1273573
Thanks Meter: 3,779
Q Mobile A50 Read Pattern Cod Done
Q Mobile A50 Root & Read Pattern Cod Done
ANY DAMAGE OR LOST OF DATA.
great working miracle team
jamilmobile okara
The Following User Says Thank You to zulfqarali For This Useful Post:
Old 03-05-2014, 14:29   #966 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,052
Winmax W800 Pac File Read Done
   Welcome to use miracle box(World's First Fuzzy Logic Based Tool)
  SoftWare Version 1.77  Update:14-02-11
  Firmware Version:1.10
  Connected OK.
  1.Please Make sure install the driver
  2.The Phone may be required to read and write keys
  3.Pulled low may not, manually set.
  Hardware:sp8810
  Board:sp6820gb_s820v21
  CPU ABI:armeabi-v7a
  Manufacturer:SND
  Model:W800
  Android Ver:4.1
  User:BuildUser
  Baseband ver:DM_BASE_12A_W12.43|sc6820_modem|11-02-2012 17:53:08
  Build number:W22.20_P20
  IMEI1: 357414055147153
  Root:  Rooted(su)
  Done
  1. Phone switch on with battery
  And Need a space of more than 500M of sd card
  2. Need to open the USB debugging
  3. Setting defined or line to phone
  4. Need Phone root.
  checking info...
  Max block Space:230M  sdcard Space:1.84G  SD:/mnt/sdcard
  Done.
  Hardware:sp8810
  Reading spl.img...(256K)
  Done.
  Reading 2ndbl.img...(1.50M)
  Done.
  Reading params.img...(256K)
  Done.
  Reading vmjaluna.img...(512K)
  Done.
  Reading modem.img...(9M)
  Done.
  Reading fixnv.img...(3.75M)
  Done.
  Reading backupfixnv.img...(3.75M)
  Done.
  Reading dsp.img...(5M)
  Done.
  Reading runtimenv.img...(3.75M)
  Done.
  Reading boot.img...(10M)
  Done.
  Reading recovery.img...(10M)
  Done.
  Reading system.img...(230M)
  Done.
  Reading userdata.img...(160M)
  Done.
  Reading cache.img...(60M)
  Done.
  Reading misc.img...(256K)
  Done.
  Reading boot_logo.img...(1M)
  Done.
  Reading fastboot_logo.img...(1M)
  Done.
  Reading productinfo.img...(3.75M)
  Done.
  Reading kpanic.img...(512K)
  Done.
  packaging...
>>file save to :C:\Documents and Settings\Administrator\Desktop\W800_140305165204
Bro:- Palash Ahammad
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-07-2014, 05:58   #967 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
MICROMAX A35 Hang When Open Lock Solved By Eagle-Eye
THIS TEST REPORT FOR 1.79 SOON WE RELEASE
Micromax A35(Bolt)
Hang When Open Lock Solved By Formate Only
BR-Team Miracle
Last edited by ...:::::NP™:::::...; 03-07-2014 at 06:38. Reason: Word Modification
The Following 5 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 03-07-2014, 10:41   #968 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
MICROMAX X292i READ FLASH/PHONE CODE
MICROMAX X292i
MSTAR CPU
READ FLASH FILE
READ PHONE CODE
ALL DONE WITH USB CABLE
TEST VER 1.79 WAIT FOR RELESE
TRULY FOR CHINA NOTHING ELSE
The Following User Says Thank You to Deepesh Sharma For This Useful Post:
Old 03-10-2014, 07:22   #969 (permalink)
zulfqarali's Avatar
Member: 1273573
Thanks Meter: 3,779
Samsung i9100 factory rest done
read info
reset facyory
IMG]http://imageshack.com/a/img843/1236/psf.gif[/IMG]
jamilmobile okara
The Following 6 Users Say Thank You to zulfqarali For This Useful Post:
Old 03-10-2014, 07:49   #970 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
OG SAMSUNG GALAXY CORE i8262 PHONE HANG SOLVED RESET IN ON EASY WAY WITH MIRACLE
Og Samsung Galaxy core I8262
Hang Problem Solv By Factory Reset On Easy Way
With
Miracle Eagle-eye
Realy No Any One Compare With Us
Team-Miracle
Old 03-10-2014, 16:42   #971 (permalink)
zulfqarali's Avatar
Member: 1273573
Thanks Meter: 3,779
Lg Optimus 3d Su760 Reset Gmail Done
Root With V Root
Gmail Reset Done
jamilmobile okara
The Following 4 Users Say Thank You to zulfqarali For This Useful Post:
Old 03-11-2014, 10:57   #972 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Intex avatar2.8t&t read phone code/flash file
INTEX AVATAR2.8T&T
READ PHONE CODE
FLASH FILE
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 03-14-2014, 10:03   #973 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,284
Kechaoda k72(mtk 6260 cpu) hang on start up problem solved by formate only
KECHAODA K72(MTK 6260 CPU)
HANG ON START UP PROBLEM SOLVED
FORMATE
RESTORE OG IMEI JUST ONECLICK
TRULY FOR CHINA
NOTHING ELSE
The Following 7 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 03-14-2014, 12:56   #974 (permalink)
Member: 1386392
Thanks Meter: 604
I-mobile S551 cpu MT6268 read and format done
( sucessfull report)
Read
The Following 2 Users Say Thank You to bakar_siddeik81 For This Useful Post:
Old 03-14-2014, 15:56   #975 (permalink)
Member: 1386392
Thanks Meter: 604
symphony m40 usb flash done Volcano box
Page generated in 0.26658 seconds with 9 queries
