12-10-2013, 10:59 | #169 (permalink) |
Freak Poster Join Date: Nov 2011 Location: ALL INDIA
Member: 1695643 Status: Offline Sonork: 1651587:vk Thanks Meter: 90 | Support: Server Communication Error (Check Firewall and TCP/IP DNS Server Settings, try to use: 8.8.8.8 and 8.8.4.4) its server problem 100% |
12-11-2013, 09:43 | #171 (permalink) |
Junior Member Join Date: Jan 2010 Location: surat gujarat
Member: 1206738 Status: Offline Sonork: [email protected] Thanks Meter: 1 | koi hai jo sahi solution de HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Authentication stage error: Connection Closed Gracefully ki |
12-13-2013, 07:35 | #172 (permalink) | |
Banned Join Date: Feb 2010 Location: sonebhadra Ramgarh
Member: 1232828 Status: Offline Sonork: 100.1647663 Thanks Meter: 49 | Quote:
uninstall all the old setup files and drivers restart the pc. install UFSx_Support_Suite_Setup_v02.03.00.03 UFSx_Support_Suite_Setup_v02.03.00.03 .exe update the driver UFS_USB_Driver_30830_W8.zip run ufs pannel Click "Check Box" Click "Update Box" Click "Check Box" - Make sure "Box Status" = "True" or "Bad Software" and "Server Status" = "Support Ok", before proceeding Switch to the "Software" Tab Click "Check Server" Click "Install" | |
The Following 2 Users Say Thank You to janu_shivam For This Useful Post: |
12-14-2013, 16:13 | #174 (permalink) |
Registered User Join Date: Jun 2013
Member: 1960994 Status: Offline Sonork: 1980 Thanks Meter: 1 | [QUOTE=bittukhan;9617686]HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Authentication stage error: Connection Closed Gracefully.[/Q UOTE] Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 98 Serial: 78739 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78739 HID: 0D2C6756436000BE, HWK: A1.04-PRO1 HWK: 0D2C6756436000BE NOT AUTHORISED, Update Box Your IP: 41.222.177.122 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 78739 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 78739 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 78739 HID: 0D2C6756436000BE, HWK: A1.04-PRO1 HWK: 0D2C6756436000BE NOT AUTHORISED, Update Box Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
12-15-2013, 11:19 | #175 (permalink) |
Freak Poster Join Date: Jul 2009 Location: JATRABARI
Member: 1080951 Status: Offline Sonork: 100.1591728 Thanks Meter: 89 | Authentication stage error: Error CPU: GenuineIntel Platform: Windows NT 5.1 (Build 2600 Service Pack 3, v.3264) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 C:\Program Files C:\Program Files\Common Files C:\Program Files\Nokia\Phoenix\ C:\Documents and Settings\Personal\Desktop C:\Documents and Settings\Personal\Start Menu\Programs App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 1 Location: 18 Serial: 7qww5 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 7tr65 HID: 7A6Eu65416r00C9, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 114.130.66.12 Support: Account Ok Something Wrong, Try to Use [Update Box] Box: 1 Location: 18 Serial: 756er5 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 766655 HID: 7A6E9dree6000C9, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Your IP: 114.130.66.12 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 7ert5 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 7tre65 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75f575 HID: 7A6E9dfgfh16000C9, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Authentication stage error: Error: Server returned unrecognized reply! Are you using latest client software version? setup is UFSx_Support_Suite_Setup_v02.03.00.02 pls help Last edited by JIBON JIBON; 12-15-2013 at 11:25. Reason: pls help |
12-20-2013, 03:20 | #178 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1961507 Status: Offline Thanks Meter: 3 | App: UFSx (HWK) Control Panel v 2.3.0.2 by SarasSoft Box: 2 Location: 273 Serial: 75256 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75256 HID: CE1A67FE4060007D, HWK: A1.04-PRO1 HWK: NOT AUTHORISED, Update Box Bad IX: ABCD Failed: -6 Your IP: 185.25.253.24 Support: Account Not Exists Something Wrong, Try to Use [Update Box] Support: Account Not Exists ????? |
12-20-2013, 03:34 | #179 (permalink) |
Member: 1961507 Status: Offline Thanks Meter: 3 | Box: 1 Location: 273 Serial: 75256 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75256 HID: CE1A67FE4060007D, HWK: A1.04-PRO1 HWK: CE1A67FE4060007D NOT AUTHORISED, Update Box Your IP: 77.247.181.163 Support: Account not Exists REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 75256 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 75256 LIC5: True BOXK: 2 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 75256 HID: CE1A67FE4060007D, HWK: A1.04-PRO1 HWK: CE1A67FE4060007D NOT AUTHORISED, Update Box Authentication stage error: Server reported error: Account for this HWK module does not exist on server. Please contact your reseller! |
