02-05-2013, 10:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: LOVE A L L AH LOVE ALQURAN
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | x2-02 flashing problem also try select manual boot only 5 file perday on support Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.41 Update:13-01-28 S/N: >>>>>About Firmware Version:1.09 Connected OK. Connecting Internet... Network connected error Fuzzy Logic Method is very safe and reliable ! Coolsand/RDAScaning Pinouts,Please press Power-Key... <<.... Abort by User Definition Applied Connecting, Power On... Done. CPU type: Coolsand (880A7002) Flash type: NOR Flash ID: 00EF0040(00160000) Flash Model: W25Q32BV Flash Size: 0x400000(4.0M) Being analyzed,Wait... Read Error. ID: 11_1 Definition Applied Connecting, Power On... Done. CPU type: Coolsand (880A7002) Flash type: NOR Flash ID: 00EF0040(00160000) Flash Model: W25Q32BV Flash Size: 0x400000(4.0M) Loading the boot,Wait.. >>BootLoad Error. ID: 11 |
02-05-2013, 10:47 | #2 (permalink) | |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Quote:
WHY YOU NEED FLASH IT? POST DETAIL AND CHANGE BOOT AND POST RESULT IF NOT SOLV THEN CONTACT ME [email protected] | |
02-05-2013, 11:02 | #3 (permalink) |
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | set is dead so want alive also try change boot same cant find auto pin its flash done on other but power on nodisplay only white |
02-15-2013, 04:44 | #5 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Barasat Age: 23
Member: 1852401 Status: Offline Sonork: 100.1627206 Thanks Meter: 8 | please check facing problem x2-02 also try select manual boot only 5 file perday on support Welcome to use miracle box(World's First Fuzzy Logic Based Tool) SoftWare Version 1.41 Update:13-01-28 S/N: >>>>>About Firmware Version:1.09 Connected OK. Connecting Internet... Network connected error Fuzzy Logic Method is very safe and reliable ! Coolsand/RDAScaning Pinouts,Please press Power-Key... <<.... Abort by User Definition Applied Connecting, Power On... Done. CPU type: Coolsand (880A7002) Flash type: NOR Flash ID: 00EF0040(00160000) Flash Model: W25Q32BV Flash Size: 0x400000(4.0M) Being analyzed,Wait... Read Error. ID: 11_1 Definition Applied Connecting, Power On... Done. CPU type: Coolsand (880A7002) Flash type: NOR Flash ID: 00EF0040(00160000) Flash Model: W25Q32BV Flash Size: 0x400000(4.0M) Loading the boot,Wait.. >>BootLoad Error. ID: 11 |
