Siemens-Benq RingTones and WallPapers NO Unlocking or Flashing threads here, this section for RingTones, Wall Papers, Games and other Staff. |
06-22-2002, 18:54 | #31 (permalink) |
No Life Poster Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | P.S. I've never asked anyone to vote for me. |
06-23-2002, 03:43 | #32 (permalink) | |
Freak Poster Join Date: Aug 2001 Location: BiH Age: 60
Member: 5601 Status: Offline Thanks Meter: 0 | Re: to: bonanza Quote:
06-24-2002, 01:03 | #33 (permalink) |
No Life Poster Join Date: Jun 2002 Age: 57
Member: 13100 Status: Offline Thanks Meter: 12 | Windows98 se Where can I get this windows version ? Becoze receive this error message whan trying to use ALL34 2.0.5.EXE crack by Xak "When I launch this soft : All 3/4 Siemens Service 2.0.5 cracked by Xak..., I receive this error message : "file ALL35 2.0.5.EXE is related to a missing export KERNEL32.DLL. And other one : a peripheral attached to the system do not work correctly" I reinstall windows 98, but same situation. pls help |
06-24-2002, 01:10 | #34 (permalink) | |
Member: 13100 Status: Offline Thanks Meter: 12 | Re: All Siemens ( repair, eeprom data demaged, language change, unlock ) freee...... Quote:
06-24-2002, 03:34 | #35 (permalink) |
No Life Poster Join Date: Jun 2002 Location: City
Member: 12663 Status: Offline Thanks Meter: 78 | READ THIS INSTRUCTIONS Use All 3/4 Siemens Service v2.0.5 (cracked by Xak) 1. Load *.flx file 2. Select COM Port and mobile type 3. Check option "Write Flash" 4. Check option "Write IMEI" 5. Check option "Burst Mode ( 10% faster ) Now U are ready to flash the phone... 6. Press "Init Mobile" and follow the program instruction's Afther flashing U need to read LOG file from phone and create a MAP file... 7. Use "Siemens IMEI Writer, Version 3.00" <-- read LOG and make MAP file 8. Now use " Siemens IMEI Writer, Version 3.00 " <-- to write MAP file to phone Afther writing MAP file to phone, your phone is ready for calls... Now is "All Done..." Note: for all people who cant start SW, and if someone receive some strange messages like ( ...export to missing Kernel32.dll or COMCTL32.dll...) they need to reinstall windows 98 SE!!! Only then, they will be able to run SW ( All 3/4 Siemens Service v2.0.5 Note: U must allways check both options "Write Flash" and "Write IMEI", only in that case U will be update your phone with full (correct) flash and eeprom.... When U check option "Write IMEI" then SW will write eeprom to phone, only IMEI cant be upload to phone, because the calcualting algorithm is inside the DONGLE!!! [email protected] Regards to all, and special regards to Xak special regards to servis1111 (ZVONE master of unlocking) U are the best man... special regards to kemoba (also one man who have give me his support all the time) thanks man P.S U dont need DONGLE for this solution !!! If U have any protection SW installed on your PC like (Norton, or McAfee etc.) then U need to reinstall your PC. Use Win98 SE. If afther reinstalling your PC U cant start this SW, then Shut Down PC and go work something else... Then I cant help U. Sorry... Regards to all... |
06-24-2002, 23:29 | #40 (permalink) |
Member: 13100 Status: Offline Thanks Meter: 12 | KERNEL32.dll and comctl32.dll Pls can any one send me his KERNEL32.dll and comctl32.dll in working win98se with All3/4 2.0.5.exe crack by Xak ? mine don't work. i reinstall many time and don't work I say |
06-27-2002, 01:44 | #44 (permalink) |
Member: 12663 Status: Offline Thanks Meter: 78 | To: watch man Dont use this SW to "Write IMEI" !!!!! Read one more time whole info!!! Use only this SW for full flashing phone like this ( if your phone is totaly dead, or need new lang pack, or eeprom data demaged )! In that case U must check both options "Write Flash" and "Write IMEI" even now IMEI will be not upload to the phone, but this is important because U will now upload correct eeprom to phone!!! Afther flashing U need to read LOG from phone and make MAP file. When U send MAP file to phone, phone will be working without problems. Regards to all... |
06-27-2002, 08:58 | #45 (permalink) |
Crazy Poster Join Date: Jun 2002 Location: thailand Age: 52
Member: 13272 Status: Offline Thanks Meter: 0 | I had install new window 98 SE and run the all34 2.0.5 . the program is error, it show "The all34 2.0.5 file is linked to missing export KENNEL32.dll" . How can I solve this problem. |
All box repair eeproms is here | alis | Off Topic Zone | 0 | 12-07-2009 09:07 |
all siemens repaire solution | sulai2k | Siemens Hardware Repair Area | 0 | 03-20-2007 12:11 |
s35 problem EEprom data demaged | Rakun | x1x to x45/x50 | 0 | 09-16-2002 21:41 |
siemens C45 EEPROM DATA DAMAGE | jrabbit1 | x1x to x45/x50 | 1 | 08-09-2002 19:12 |
All Siemens Repair & Unlock!!! | kemoba | Main Sales Section | 2 | 06-19-2002 16:52 |
