A750F A7(2018) could not do normal boot, invalid kernel length" hi guys,, today i received a a750f which is only shows "could not do normal boot,invalid kernel length" so i try to flash with latest pie version but facing "no pit partition" error can any one provide 'pit' file???? pls |
Post log mate, screenshot. Br, xerraco |
can you share pit file?? |
File analysis... OK Total file size: 0x89F9BD00 (2207 Mb) Searching USB Flash interface... COM4 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.36.8 https://pasteboard.co/IoSWSIY.jpg |
Sometimes happens, when pc hase low power on usd |
hello i have same problem how u fix it a750f |
Hi I have also same problem with A305f could not do normal boot, invalid kernel length any solution pls |
how? any solution? pls |
If a custom recovery TWRP is flashed and then after twrp you turn OEM ON, won't you get this message? OEM ON with custom binary flashed is a BIG no no. Flash same binary firmware or latter one to get phone working? |
I have also same problem with a305f plese give me any solution i am trying flash with same binary also but flashing failed pit error showing |
Plese if you find any solution also share with me i am also facing same problem with a305f |
Have you try with the very latest version of odin? odin3-v3-13-3 download Sometimes using box program may not work, as the odin protocol may not be updated and not flash correctly. |
same a750F show this error cant flash pit error same a750F show this error cant flash pit error |
DOes anyone know how to sort out this ISSUE??? |
FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A750F Software version: 41.11 File analysis... OK Total file size: 0x17313559F (5937 Mb) Searching USB Flash interface... COM13 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.41.11 |
