Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
08-08-2020, 00:03 | #1 (permalink) |
Junior Member Join Date: Sep 2015 Location: Bosna i Hercegovina
Member: 2465876 Status: Offline Thanks Meter: 16 | G973F U8 FRP Bypass First in the world Security patch August 2020 Didn't have third phone to record so I will write way to bypass google account You will need two phones for this bypass Phone #1 will be the phone with frp Phone #2 will be the phone that you need to bypass phone #1 1.Connect to your wifi network on phone #1 so you can download smart switch 2. Go to add wifi network 3.When keyboard pops up tap on GIF icon and then select "Go to Galaxy Store" it will ask you to update galaxy store so do that 4.Search for Smart Switch, update it, install and run 5.Use phone #2 with your google account logged in and connect it with your phone #1 using smart switch via usb or wifi (on phone #1 select receive data, on phone #2 select send data) 6.Select any app to transfer to phone #1 and tap "Start" 7.phone #1 will then ask you do you wish to copy google account from other phone, if yes tap copy on other phone, and then you tap copy on phone #2 after that you need to enter password for your google account on your first phone 8. phone will then copy your google account from #2 phone to #1 phone 9. when it is finished you will see "Go to home screen", and then you just need to restart device and set it up, after that enable oem lock and restart and frp will be off I hope this guide will help you, I've tried my best to describe steps for bypass |
The Following 7 Users Say Thank You to saleee277 For This Useful Post: |
08-11-2020, 09:43 | #3 (permalink) |
Member: 2465876 Status: Offline Thanks Meter: 16 | I have used my personal phone to transfer, maybe that's why it is working. I have tried with other clean phone with just smart switch and google account id didn't work. But with my personal phone it did, maybe because I use it longer with g. acc. logged in |
08-26-2020, 13:39 | #6 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Samsung
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | All SAMSUNG Android 10 FRP Unlock/Google Account Bypass - NO APK/APPS INSTALL FIXED - AUGUST 2020 |
The Following User Says Thank You to Mobile-Lab For This Useful Post: |
08-27-2020, 08:58 | #7 (permalink) | |
Insane Poster Join Date: Jan 2007 Location: algeria
Member: 423717 Status: Offline Thanks Meter: 11 | Quote:
worked for me thanks | |
10-01-2020, 14:02 | #9 (permalink) | |
Insane Poster Join Date: Sep 2015
Member: 2458311 Status: Offline Thanks Meter: 20 | Quote:
Thank your effort ,finally your solution help me. I know that you wasting your time to test/try your solution ,and i'm really do apprechiate it. Thanks to you i did not spend 15 Usd on adyunlock to remove the Frp witk remote soluton. So again ,Thanks man!! | |
