Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-08-2014, 08:39 | #50 (permalink) | |
Freak Poster Join Date: Jan 2009
Member: 960720 Status: Offline Thanks Meter: 8 | Quote:
This is trick works fine Thank you | |
04-23-2014, 05:54 | #54 (permalink) |
Junior Member Join Date: Sep 2010 Location: india
Member: 1403828 Status: Offline Sonork: sasukhan Thanks Meter: 1 | first press power key suddenly press vol plus and home key (center key ) after on display release only power key not vol up and home key after that phone show whipe data factory reset use up down for volume key press power is for ok |
04-25-2014, 14:40 | #57 (permalink) | |
Crazy Poster Join Date: Sep 2009
Member: 1119195 Status: Offline Thanks Meter: 34 | Quote:
04-28-2014, 13:13 | #58 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Before performing the Hard Reset: - In case your Samsung mobile phone can connect to a computer then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how. - But in case that is not possible then you can check that your phone's battery has enough charging, Otherwise you should charge it. Samsung Galaxy Star Pro Duos GT-S7262 Hard Reset Steps: - Turn your device off. - Take out its battery, SIM-card and memory card too. - After 10 seconds put the battery back into your phone, But do not turn it on. - Press and hold the Volume Up key + the Home key then press the Power key. - Keep pressing the above keys until Samsung logo appears,Then release The Power Key only. - Keep pressing The Volume Up Key and Home Key until you get Factory reset / System Recovery menu on screen. - Use the Volume Down key to select Wipe Data / Factory Reset option. - Use the Power key to confirm the operation. - You need to use the Volume Down key again to select "Yes -- delete all user data" - Use the Power key to confirm. - After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key. - Now the phone will reboots, Wait for it to be fully on and then you can start using it. |
04-30-2014, 14:14 | #60 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | YOu solution make my mobile white display.. Where are admin to remove this post which is doing brick users mobile |
