Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-16-2014, 13:04 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: kpk _PAK
Member: 1358184 Status: Offline Sonork: 100.1616912 Thanks Meter: 615 | 1.Install Kies 2.Run Kies, and connect your mobile phone to your PC using USB cable 3.Kies will guide you through the installation process |
The Following User Says Thank You to aliyousafzai For This Useful Post: |
03-16-2014, 13:04 | #5 (permalink) |
Member: 1358184 Status: Offline Sonork: 100.1616912 Thanks Meter: 615 | Upgrade using PC suite:- Step 1: You need Samsung kies. Step 2: Install it on your PC. Step 3: You need an internet connection to upgrade your firmware through kies. Step 4: Then connect your Samsung mobile via USB data cable. Device driver will get installed automatically. Before connecting with data cable with pc enable USB debugging on your phone in setting menu . Step 5: Your kies application automatically ask to update an kies application according to phone hardware or libraries like something. Accept it and update it Step 6: Then after updating it will automatically shows your mobile model number on the left side corner on Kies. Then it will be like this (image seen below) Step 7: It will automatically shows an update if your mobile has an update with latest firmware like this or else go to tools menu on kies click upgrade firmware option. Step 8: Click the update button to upgrade your firmware. It will automatically flash the new firmware on your Samsung handset.Don’t disconnect your USB data cable will updating the firmware. Your updating speed depends upon your internet speed. br aliyousafzai Last edited by aliyousafzai; 03-16-2014 at 13:09. |
