Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-23-2014, 19:56 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 588 | I9100 S2 not detect sim card with pin The phone had corrupted imei like 0049xxxxx I rooted it and repaired imei tried it with some simcards i had without pin and worked fine. When customer came to pickit up he asked me to test his simcard but phone does not read it. I disablef the pin in sim card and worked fine. What can be the problem and the solution. REGARDS TO ALL PUNTO-MOVIL |
02-23-2014, 20:50 | #2 (permalink) |
Super Moderator Join Date: May 1999 Location: Wien/Austria Age: 48
Member: 16 Status: Offline Sonork: 100.1652085 GSMWorld Thanks Meter: 1,743 | Hi, Are you sure looked sim slot ok?
__________________ Wbr GSMWorld |
The Following User Says Thank You to GSMWorld For This Useful Post: |
02-23-2014, 23:09 | #3 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 588 | Yes brother simcard slot working perfect .I tested many simcards coverage and calls works great. when i introduce a sim card with pin the phone just ignore it and pass directly to the menu. I put a sim card with pin, the phone ignored it but in the same phone i deactivated the pin request and the coverage bars showed up with the operator name and worked normal. |
02-24-2014, 06:04 | #4 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | Hello Hi, this is a refurbished i9100 phone. If phone version is 4.12, phone goes off when you press power button, it does not give options to restart or power off. The only way to solve this is to flash version 2.35 only, have a nice day. |
The Following User Says Thank You to ahmedksal For This Useful Post: |
02-24-2014, 09:47 | #5 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 588 | This is true brother. Handset power off directly without giving any option. Till now customer has not come back.i will try your solution. Best Regards. Punto-Movil |
02-25-2014, 23:09 | #6 (permalink) | |
Member: 16 Status: Offline Sonork: 100.1652085 GSMWorld Thanks Meter: 1,743 | Quote:
Please read full info from phone and post here log...
__________________ Wbr GSMWorld | |
07-15-2014, 12:49 | #7 (permalink) |
Insane Poster Join Date: May 2007
Member: 514764 Status: Offline Sonork: 100.1581189 Thanks Meter: 4 | samsung not detect sim card with pin i am having same problem in smasung phone i bought mother board from samsung s6500 ,s5300 , i9100 all these phones won't read sim card wih pin if i disactivate pin number it reads sim card, and netwok 100%, and 3g works perfect in above post if the version i9100version 2.3.6 yes asks pin no if version 4.1.2 not asking pin no thanks |
07-15-2014, 15:18 | #9 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: India
Member: 350719 Status: Offline Sonork: 100.1623850 Thanks Meter: 157 | Quote:
The Following User Says Thank You to .::intel32::. For This Useful Post: |
