Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-16-2014, 09:29 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: PAKISTAN Age: 52
Member: 81821 Status: Offline Thanks Meter: 14 | i9300 flashing problem ----------------------------------------------------------------------------------- To connect GT-S5360 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. Selected firmware file: I9300XXELL4_I9300O2UELL1_I9300BWELK1 _HOME.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SYSTEM section... SYSTEM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing Firmware Failed plz help |
