i9505 can't connect to a network please help Hi all, for some reason I can't read info on or unlock or repair imei. I've searched the forum but can't find a solution. Any help would be much appreciated. I have full bars on the s4 but when I try to make a call it comes up with "not registered on network" help.... Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.18.0 Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Reading phone info... fail Done with Samsung Tool v.18.0 Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 No answer from phone Done with Samsung Tool v.18.0 |
And on another one I'm getting a reading security error access denied. |
Post In Right Section Always What You Want? Post Here Full Detail First Root Phone After Root Update Su If Your Phone is Unlocked And Not Registerd on network Write Cert In Phone Wbr Hifzul Amin |
*#0808# choose modem+adb. choose correct com in z3x and unlock. don't forget to root before... |
root phone 1st open super user update binary and disable knox conect via the usb cable #0808# choose modem+adb wait for drivers to install select com port in z3x repair im ei or rite new qcn or cert file |
Thanks guys I spent so long looking around the forum. So one more question how do I update binary and disable knox, I opened super user but can't see the options ? do I need to upgrade to pro? Thanks again |
- Root easy with this: CF-Auto-Root-jflte-jfltexx-gti9505 , (can find in google or here "root any device" thread, above button in dasboard forum), flash with Odin in AP/PDA fiel with phone in D.Mode. - at restart, (not touch nothingh first), go in app and click in SU icon, "disable Knox" press ok - Uptate you Z3X to 18.3 you are using obsolete version. - Set phone how "Help Button", *#0808# "DM+MODEM+ADB" for microusb cable - connect phone to usb 2 directly motherboard pc an open Z3X sw then select I9505 - If have 4.3 or more gigh fw version, ceck "New Security" and z3x usb port - Make operaction you want, if unlock, or with "Read codes", (if supported), or direct "Unlock - For Imei, NOT skipe "Nv Bkc Read/write", then press "Repair" insert you Imei and press ok - leave that sw work, phone reboot 1/2 time, then finish - Insert unaceptated sim or wich have issue, wait 3/4 min.s if not get signal, search manually network, (this only first time), select and enjoy P.d. not have write procedure with QCN or CERT becouse for this model isn't necessary, tested 100% use only Thanks button as forum rules BR allumts:) |
Still no luck its coming up with com not found and if its in the other usb ports the phone comes up not found |
Post always in right secrtion, this isn't Z3X section. BR allumts |
What is zx3 ? -- newbie |
