Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 11-26-2014, 02:15   #1 (permalink)
Member: 2266701
i9505 can't connect to a network please help
Hi all, for some reason I can't read info on or unlock or repair imei. I've searched the forum but can't find a solution. Any help would be much appreciated. I have full bars on the s4 but when I try to make a call it comes up with "not registered on network" help....
Selected model: I9505
Selected port: COM3 Z3X BOX Serial Port
Selected port speed: 115200
Reading phone info...
Reading phone info... fail
Done with Samsung Tool v.18.0
No answer from phone
Old 11-26-2014, 04:55   #2 (permalink)
Member: 2266701
And on another one I'm getting a reading security error access denied.
Old 11-26-2014, 08:23   #3 (permalink)
Hifzul Amin's Avatar
Member: 2144988
Sonork: 100.1655364(Offline)
Thanks Meter: 217
Post In Right Section Always
What You Want?
Post Here Full Detail
First Root Phone
After Root Update Su
If Your Phone is Unlocked And Not Registerd on network
Write Cert In Phone
Wbr
Hifzul Amin
Old 11-26-2014, 12:57   #4 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
*#0808# choose modem+adb. choose correct com in z3x and unlock. don't forget to root before...
Old 11-26-2014, 21:08   #5 (permalink)
Member: 2284628
Thanks Meter: 47
root phone 1st
open super user update binary and disable knox
conect via the usb cable
wait for drivers to install
select com port in z3x
repair im ei or rite new qcn or cert file
The Following User Says Thank You to repairs.wales For This Useful Post:
Old 12-04-2014, 00:43   #6 (permalink)
Member: 2266701
Thanks guys I spent so long looking around the forum. So one more question how do I update binary and disable knox, I opened super user but can't see the options ? do I need to upgrade to pro?
Thanks again
Old 12-04-2014, 11:22   #7 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Thanks again
No need any upgrade a pro.
- Root easy with this: CF-Auto-Root-jflte-jfltexx-gti9505 , (can find in google or here "root any device" thread, above button in dasboard forum), flash with Odin in AP/PDA fiel with phone in D.Mode.
- at restart, (not touch nothingh first), go in app and click in SU icon, "disable Knox" press ok
- Uptate you Z3X to 18.3 you are using obsolete version.
- Set phone how "Help Button", *#0808# "DM+MODEM+ADB" for microusb cable
- connect phone to usb 2 directly motherboard pc an open Z3X sw then select I9505
- If have 4.3 or more gigh fw version, ceck "New Security" and z3x usb port
- Make operaction you want, if unlock, or with "Read codes", (if supported), or direct "Unlock
- For Imei, NOT skipe "Nv Bkc Read/write", then press "Repair" insert you Imei and press ok
- leave that sw work, phone reboot 1/2 time, then finish
- Insert unaceptated sim or wich have issue, wait 3/4 min.s if not get signal, search manually network, (this only first time), select and enjoy
P.d. not have write procedure with QCN or CERT becouse for this model isn't necessary, tested 100%
use only Thanks button as forum rules
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 12-10-2014, 02:21   #8 (permalink)
Member: 2266701
Still no luck its coming up with com not found and if its in the other usb ports the phone comes up not found
Old 12-10-2014, 11:37   #9 (permalink)
allumts's Avatar
Member: 1564612
Post Screenshoot of phone Rootted and all steps you do, w/o Screenshoot and step by step procedure posted above is impossible that only you cannot connect this easy I9505
Post always in right secrtion, this isn't Z3X section.
allumts
Old 02-28-2016, 08:26   #10 (permalink)
Member: 2018846
What is zx3 ?
-- newbie
Page generated in 0.19793 seconds with 8 queries
