Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-24-2014, 14:35 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Gujrat Age: 31
Member: 1912761 Status: Offline Sonork: 100.1650678 Thanks Meter: 105 | M110S Flashed with i9000 and dead, Boot repaired Successfully. Don't flash M110S with I9000 files by Odin, No doubt that you can do this with proper method. But If you accidently flashed M110S with I9000 Files with odin, your phone will be hard bricked, and need to repair boot. You need Riff Box, Solder gun, Solder wire, and techniques. Make a connection with phone through wires using given method. Here we go. 1.Download M110S DLL file from support. 2.Select M110S from the list, 3.Set TCK frequency to 8khz. Press Resurrection. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [Samsung M110S V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! Done Thats it! Remove wires, put phone in download mode, flash with M110S Files. Phone is OK! Best of Luck for your Turn. Last edited by Akaash6255; 02-24-2014 at 14:43. |
02-24-2014, 16:35 | #3 (permalink) |
Member: 1912761 Status: Offline Sonork: 100.1650678 Thanks Meter: 105 | Boot repair method for N7100 and I9300 is little different than this method. |
The Following User Says Thank You to Akaash6255 For This Useful Post: |
04-08-2014, 08:26 | #4 (permalink) |
Member: 1912761 Status: Offline Sonork: 100.1650678 Thanks Meter: 105 | HTC 8x Boot Repaired :) No need to attach battery or Power Supply, Just attach usb cable, and solder jtag wires on 8x Jtag pad. Press Resurrection. Here we go!!!!! Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC 8X (PM2330000) V1.0.4856.56572] Connecting to the dead body...OK Detected dead body ID: 0x406B50E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x014A (H8G2D, 0x0001CE800000 Bytes = 7.23 GB) Detected an Initialized FLASH2 Chip, ID: 0x0090/0x014A (H8G2D, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 7.23GB Flashing the dead body...OK Resurrection complete! BR |
