Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-09-2014, 22:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2014
Member: 2136780 Status: Offline Thanks Meter: 68 | [OS4.3] Wifi Fix | Root | DeKnox | Debloat | CSC features | Build prop [Tool] Root | DeKnox | Debloat | CSC & Build.prop Fs | EFS | Wifi FIX on Old bootloader I am rewriting this thread to make available common tool at one place. Though this tool is available since long but newbies unable to find it. Here is description How this tool can be useful on latest 4.3 ROM Features Code: Root & Busybox DeKnox Recovery Flasher Backup & mass bloatware remover Restore Odex Remover Customize bloat remover Customize CSC Features Tweaks LockScreen security bypass Push System Apks GPS Fixer How to use This Tool Download Philz recovery (avoid latest v) from here and flash using Odin with PDA tab. Newbie can refer this image Download DrKetan Multitool adv V6 and copy to SD card Reboot to recovery (Home + Power + Vol up) Select Install zip from SD card and navigate to Multitool file you have copied as said above and flash This will start Aroma and now follow wizard. Remember you have to select option which you needs, you can skip any option which you don't like. For detail description of features refer this Thread post #1 & #3 After Root with this tool if you get FC SuperSU / Binary update fail, for that just update it from play store and it should work fine. soruce :xda |
03-09-2014, 22:08 | #2 (permalink) |
Member: 2136780 Status: Offline Thanks Meter: 68 | For N7100 s all of you are knowing latest 4.3 built have new bootloader and samsung have implemented knox security. Also note that latest leaked 4.3 (MK4) having new bootloader and it may not be downgrade. I will update this post later for details. If you want to use latest ROM without bootloader, you may need to use wifi patch. Download wifi patch , extract and flash with Odin for PDA tab. I already have mention this on one of my thread but making this separate so any bootloader related stuff can be posted at single place |
