Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-13-2014, 09:22 | #1 (permalink) |
Freak Poster Join Date: Mar 2013 Location: ACCRA GHANA Age: 27
Member: 1908579 Status: Offline Thanks Meter: 21 | p1000 boot problem |
03-13-2014, 23:11 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Mind
Member: 2147085 Status: Offline Thanks Meter: 53 | When Booting the device got stuck at the Samsung Logo Screen ODin/Heimdall fails on any rom which include an hidden rfs and movinand mst ODin/Heimdall report success when flashing flashing roms without hidden rfs and movinand mst Recovery Mode reports errors after flashing The error is different depending on which rom was flashed but are all related to file system functions Internal MMC checksum verify failed E: failed to mount /system (invalid argument) E: failed to mount /dbdata (Invalid argument) E: /dev/block/mmcblk0p2 on /data failed: No such file or directory E: copy_dbdata_media:Can't mount /dbdata The Problem The recovery errors alone are not enough to diagnose the problem as they can also occur if flashing has been carried out incorrectly The main pointer to an Internal SDCard Failure is the inability to flash hidden rfs and movinand mst You should be able to confirm this to be the case by running dmesg on the device using adb from the command prompt Code: adb shell dmesg My output contained the following line: Code: <3>[ 4.802004] mmc0: error -110 whilst initialising MMC card The Solution Normally you should be able to RMA this as it is an hardware failure However as warranties expire or you just can't be bothered to wait here is an alternative solution 1. Format the external sdcard with 3 parititions (you can probably get away with 2) I used a 32 GB card with the follwing Partition 1: 28 GB Fat 32 (sdcard partition) Partition 2: 4 GB ext4 (data partition) Partition 3: 100MB Fat 32 (preload partition) If you want more space for app, make the data partition larger 2. Flash Latest Rom. I used XWJQ8 but I also flashed XXJPZ Successfully and I don't think it makes alot of difference I Used Heimdall for this and I flashed everything Odin should do the Job as long you remove hidden rfs and movinand mst from the tar balls Code: heimdall flash --repartition --pit gt-p1000_mr*pit --primary-boot boot_bin \ --cache cache*rfs \ --factoryfs factoryfs*rfs \ --modem modem*bin \ --param param*lfs \ --secondary-boot Sbl*bin \ --kernel zImage --recovery zImage 3. Flash latest Overcome Kernel 4 which can be downloaded from the teamovercome download page 4. Boot To Recovery ( You should now see Clockwork Recovery Mod ) 5. edit /system/etc/vold*fstab on the device to look like the following Code: # internal sdcard { ums_path = /sys/devices/platform/usb_mass_storage/lun0/file asec = disable discard = disable format_option = -r 1558 } dev_mount sdcard /mnt/sdcard 1 /devices/platform/s3c-sdhci*2/mmc_host/mmc1 # externel sdcard { ums_path = /sys/devices/platform/usb_mass_storage/lun0/file asec = enable } dev_mount sdcard /mnt/sdcard/external_sd auto /devices/platform/s3c-sdhci*2/mmc_host/mmc2 /devices/platform/s3c-sdhci*2/mmc_host/mmc1 6. Reboot, System Should now functioning normally. Note: First boot takes a while. if you are worried or think it is boot looping, you can watch the output using adb logcat You should now have a working galaxy with the added bonus of a re-sizable data partition. |
