Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
04-06-2011, 11:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 44
Member: 88333 Status: Offline Thanks Meter: 48 | p1000 problem when trying to flash... i have flashed it with the pit file and i got the green passed message so i took out the usb cable and clicked reset and then i selected the flash files so i put the p1000 in download mode again and clicked "start" but here i made a photo of what happens... the first photo is what happened when i clicked start the second photo is after,when i tried again to press start. im stuck at the second photo,please if anybody could give me an hand it would be great!! thanks a lot in advance |
04-08-2011, 17:51 | #6 (permalink) |
Freak Poster Join Date: Nov 2009 Location: IRAN
Member: 1153045 Status: Offline Sonork: 100.1638693 Thanks Meter: 123 | i faced this problem yesterday Disconnect all you boxs,modems and external devices and restart your pc, install samsung android modem and then try if dosen't answer , use another computer that be clean of other boxes software and drivers i used another computer and solved |
04-09-2011, 01:46 | #8 (permalink) |
Member: 88333 Status: Offline Thanks Meter: 48 | i was able to go a little further and i got where it says: <ID:0/003> Added!! <ID:0/003> Odin v.3 engine (ID:3).. <ID:0/003> File analysis.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Set PIT file.. <ID:0/003> DO NOT TURN OFF TARGET!! <ID:0/003> Get PIT for mapping.. <ID:0/003> Firmware update start.. <ID:0/003> modem.bin <ID:0/003> boot.bin <ID:0/003> Sbl.bin <ID:0/003> param.lfs <ID:0/003> factoryfs.rfs <ID:0/003> <ID:0/003> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/003> Removed!! <ID:0/003> Added!! <ID:0/003> Odin v.3 engine (ID:3).. <ID:0/003> File analysis.. <ID:0/003> Set PIT file.. <ID:0/003> DO NOT TURN OFF TARGET!! <ID:0/003> Can't open the specified file. (Line: 1044) <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/003> Removed!! <ID:0/003> Added!! <ID:0/003> Odin v.3 engine (ID:3).. <ID:0/003> File analysis.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Enter CS for MD5.. <ID:0/003> Leave CS.. <ID:0/003> Set PIT file.. <ID:0/003> DO NOT TURN OFF TARGET!! <ID:0/003> Get PIT for mapping.. <ID:0/003> Firmware update start.. <ID:0/003> modem.bin <ID:0/003> boot.bin <ID:0/003> Sbl.bin <ID:0/003> param.lfs <ID:0/003> factoryfs.rfs <ID:0/003> <ID:0/003> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) it starts flashing but it gives me failed after a little bit,what could be the problem???perhaps wrong files? thanks a lot in advance i am also posting a photo to explain better where i am at thanks again |
04-09-2011, 02:24 | #9 (permalink) |
Member: 88333 Status: Offline Thanks Meter: 48 | also what are these files: cache.rfs dbdata.rfs factoryfs.rfs param.lfs zImage i dont know how to flash them,odin doesnt let me select them for flashing i was able to use: P1_add_hidden.pit GT-P1000-CSC-MULTI-OXXJK2.tar.md5 MODEM_P1000XXJK5_REV_00_CL690077.tar.md5 P1000XWJJ7-REV03-ALL-CL669843.tar.md5 please somebody can clear me out the differences among those files? thanks again |
04-09-2011, 02:40 | #10 (permalink) |
Member: 88333 Status: Offline Thanks Meter: 48 | i discovered that all the files: cache.rfs dbdata.rfs factoryfs.rfs param.lfs zImage are inside P1000XWJJ7-REV03-ALL-CL669843.tar.md5 so when i flash the p1000 i have to flash all modem csc and P1000XWJJ7-REV03-ALL-CL669843.tar.md5 or i can only flash the last file and the pit file? thanks a lot |
04-09-2011, 08:57 | #11 (permalink) | |
Member: 1153045 Status: Offline Sonork: 100.1638693 Thanks Meter: 123 | Quote:
try another version. . | |
04-16-2011, 08:53 | #14 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | Here is what you must note some firmwares come with just one file and that is the pda, flashing the pda you must put pit 512 and the pda file and flash, after using only the pit and partion option, do not extract the tar file some firmwares when extracted from rar has 3 files, phone, pda, csc in flashing these files you must put a hidden pit in pit tab and check repartition then start, (only pit) when it show pass load the the 3 files without pit and without repartition. Reasons for that error, firmware downgrade is atimes not allowed by bootloader, so if you are not sure, always go for the latest firmwares in support. Eg if the phone had jk1, you must flash jk2 before jk5 so if you are not sure, go for firmwares that has no extention use jm5 firmware i recommend. |
04-16-2011, 08:56 | #15 (permalink) | |
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | Quote:
perform the same procedure with this firmware p1000_xwjmf from News - www.**************** 100% firmware problem you have | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
