Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-08-2018, 16:21 | #16 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | 1 adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 2. adb shell am start -n com.google.android.gsf.login/ this one i get error 3. adb shell am start -n com.google.android.gsf.login.LoginActivity thsi one to error not internal command ! |
09-08-2018, 16:57 | #18 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2862279 Status: Offline Thanks Meter: 1 | The last 2 will be error bad command. Doesnt matter. If you on combination rom, flash with HOME CSC. if you flash the normal one you have to redo Sent from my G8142 using Tapatalk |
09-08-2018, 18:08 | #20 (permalink) |
Member: 2862279 Status: Offline Thanks Meter: 1 | Ok. Follow this process. Flash combination file. Enable debugging. Open adb terminal on pc and connect phone to computer. adb devices Enter the 3 frp command (your 3rd command has additional spacing, its wrong). The last 2 command will give error bad command. Dont worry. Flash stock rom (with CSC home, to retain settings.) Sent from my G8142 using Tapatalk |
09-08-2018, 18:38 | #21 (permalink) | |
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Quote:
Code: CODE 1: adb shell content insert –uri content://settings/secure –bind name:s:user_setup_complete –bind value:s:1 CODE 2: adb shell am start -n com.google.android.gsf.login/ CODE 3: adb shell am start -n com.google.android.gsf.login.LoginActivity | |
