Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
03-07-2014, 02:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | s5830i not erased pattern locked tried to hard reset and doesnt work ( vol+ & home & power ) to no avail . restored with odin 3.07 with 3 different firmwares and odin says it flashed ok but it didnt, it remains with pattern lock . log of odin flash ok : Code: <ID:0/014> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> S5830iXXMJ2_S5830iITVMK1_S5830iXXMJ1_HOME.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/014> Odin v.3 engine (ID:14).. <ID:0/014> File analysis.. <ID:0/014> SetupConnection.. <ID:0/014> Initialzation.. <ID:0/014> Get PIT for mapping.. <ID:0/014> Firmware update start.. <ID:0/014> sbl.bin <ID:0/014> NAND Write Start!! <ID:0/014> BcmCP.img <ID:0/014> boot.img <ID:0/014> system.img <ID:0/014> param.lfs <ID:0/014> csc.rfs <ID:0/014> RQT_CLOSE !! <ID:0/014> RES OK !! <ID:0/014> Removed!! <ID:0/014> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) Code: <ID:0/014> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> PDA_S5830i_XXLF3.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CSC_S5830i_ODDLF1.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> MODEM_S5830i_DDLF1.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/014> Odin v.3 engine (ID:14).. <ID:0/014> File analysis.. <ID:0/014> SetupConnection.. <ID:0/014> Initialzation.. <ID:0/014> Get PIT for mapping.. <ID:0/014> Firmware update start.. <ID:0/014> boot.img <ID:0/014> NAND Write Start!! <ID:0/014> param.lfs <ID:0/014> system.img <ID:0/014> BcmCP.img <ID:0/014> Transmission Complete.. <ID:0/014> Now Writing.. Please wait about 2 minutes <ID:0/014> Receive Response from boot-loader <ID:0/014> csc.rfs <ID:0/014> RQT_CLOSE !! <ID:0/014> RES OK !! <ID:0/014> Removed!! <ID:0/014> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
03-07-2014, 02:19 | #2 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | flashed with odin 1.84 and still same problem . cant enter recovery mode & after flash phone remains with too many pattery attempts Code: <ID:0/014> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> PDA_S5830i_XXLF3.tar.md5 is valid. <OSM> MODEM_S5830i_DDLF1.tar.md5 is valid. <OSM> CSC_S5830i_ODDLF1.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/014> Odin v.3 engine (ID:14).. <ID:0/014> File analysis.. <ID:0/014> SetupConnection.. <ID:0/014> Initialzation.. <ID:0/014> Get PIT for mapping.. <ID:0/014> Firmware update start.. <ID:0/014> boot.img <ID:0/014> param.lfs <ID:0/014> system.img <ID:0/014> BcmCP.img <ID:0/014> Transmission Complete.. <ID:0/014> Now Writing.. Please wait about 2 minutes <ID:0/014> Receive Response form LOKE <ID:0/014> csc.rfs <ID:0/014> RQT_CLOSE !! <ID:0/014> RES OK !! <ID:0/014> Completed.. <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/014> Removed!! <ID:0/029> Added!! <ID:0/029> Removed!! |
03-07-2014, 02:34 | #3 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | flashed with odin 3.09 and same problem . any help ? Code: <ID:0/014> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CSC_S5830i_ODDLF1.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> MODEM_S5830i_DDLF1.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> PDA_S5830i_XXLF3.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/014> Odin v.3 engine (ID:14).. <ID:0/014> File analysis.. <ID:0/014> SetupConnection.. <ID:0/014> Initialzation.. <ID:0/014> Get PIT for mapping.. <ID:0/014> Firmware update start.. <ID:0/014> SingleDownload. <ID:0/014> boot.img <ID:0/014> NAND Write Start!! <ID:0/014> param.lfs <ID:0/014> system.img <ID:0/014> BcmCP.img <ID:0/014> Transmission Complete.. <ID:0/014> Now Writing.. Please wait about 2 minutes <ID:0/014> Receive Response from boot-loader <ID:0/014> csc.rfs <ID:0/014> RQT_CLOSE !! <ID:0/014> RES OK !! <ID:0/014> Removed!! <ID:0/014> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
