Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
05-13-2024, 12:12 | #1 (permalink) |
Insane Poster Join Date: Sep 2016 Location: Pakistan
Member: 2619139 Status: Offline Thanks Meter: 20 | Samsung FRP Bypass Without PC [Free Working Guide] We sometimes perform a Hard Reset to break the password-protected screen lock. Humans tend to forget things, we can forget the password or pattern lock of our device. Now after forgetting the screen lock, we can only perform a Factory Reset operation to remove that lock easily. But what happens when you factory reset an Android device? Well, the answer to that question is quite simple, the Android OS will still protect the important data of the device. Performing a Hard Factory Reset is easy on any Android device. Imagine someone took your device and applied this procedure to remove the screen lock, and after that, that person would get full access to your data. FRP Lock | Useful Feature for Samsung Galaxy However, it is not that simple, Android knew that it was going to happen to many users, therefore, they introduced the Factory Reset Protection or FRP lock to all of their devices. Whether it is a Smartphone or a Tablet, all the devices will have to provide the previously submitted Google account details to get complete access to a particular device. In the worst-case scenario, suppose you forget both of the details, the Password or Pattern lock, and the Google account login email ID and Password. In this case, we are going to apply a method that helps to easily bypass the FRP lock from any Android device. Remember, this guide is for educational purposes, and only to provide a working solution to the genuine and authentic Android device owner. Samsung FRP Bypass Without PC Android 13, 12, and 11 Bypass Google account verification from Samsung Galaxy smartphones and tablets without a PC for free with the help of this guide. In this guide, we will show you how easy it is to remove the Google verification lock from an FRP-locked device by just applying a few steps. If you are facing the FRP lock screen after resetting your device, then you are at the right place. We are creating multiple free guides that help our visitors easily bypass FRP lock from any Samsung Galaxy device. You can also use the FRP Bypass APK to deactivate the previously submitted Google account from your phone/tablet. Moreover, this Samsung FRP Bypass without PC method works for all the Android versions, including the Android 12, 13, and 14. Nowadays, most of the Samsung devices are getting updates to upgrade the Android version. With that in mind, we created this method for the devices that are running on the latest Android security patches. Follow the below step-by-step method to completely remove the previously submitted Google account from your device without using a PC. Samsung FRP Bypass Without PC For Android 12, 11, and 10 | Step-by-step Use the below method to easily bypass Google account verification from Samsung Galaxy devices with Android Operating System Version 12, 11, and 10. Not only this, but you can also apply the below free guide for devices with Android versions 9, 8, and 7. This method does not work for Android versions 13, and 14 but works for almost all the versions. 1. Power on your device and then push the Start button from the welcome screen and tap on the agree button. 2. Connect to a Wi-Fi network and then hit the next button. When you see "Confirm Pattern" tap on Use my Google account instead. 3. Now here, as you can see the Google account verification lock asks me to enter the Gmail ID and Password. But as I don't remember the login details, I will have to bypass it. To do that, simply go back to the welcome page and then push and hold "Volume UP + Power Button" together. 4. Now draw a big reverse "L" on your screen to activate the TalkBack Settings. Once you see the popup window, double-tap on the "While using the app" option. (Remember, as soon as we activate the TalkBack Settings. Now, we need to double-tap on each option to select it.) 5. After that, it will ask you to enable the voice commands on your phone. Double tap on the "Use voice commands" option. Just after selecting this option, it will activate the voice command app, now we need to quickly speak "Google Assistant" to open this application. .............. COMPLETE GUIDE: SAMSUNG FRP BYPASS WITHOUT PC |
The Following User Says Thank You to George Matthew For This Useful Post: |
