Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
11-22-2014, 17:09 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Samsung Galaxy Mega I9200 After update touch not working Solution Here Tested Samsung Galaxy Mega I9200 After update touch not working Solution Here Tested Guide: MySelf This Solution Tested & Done By : allumts Note: This file Only fix Bootloop issues Always Booting in recovery mode, after update to 4.4.2 hang Logo Only recovery mode & Touch not working after update to kitkat. Tested Downgrade from 4.4.2 to 4.2.2 Tested vit out any issues Firmware Flashing Method: * Put Mobile in Download Mode By Holding Vol dwn + Home + Pwr * Cnnt vit pc using Usb * Run Odin * Select File in PDA * Uncheck Auto Boot in Odin (Important This Step ) * Click Start * After Flash complete remain with Blu line, but not import after PASS only Important. * Just take out battery, wait 30 sec.s and put back the battery power on phone, itself goes in Recovery mode, or manually put recovery mode just select Wipe/Factory reset and reboot, all working fine. Note:Tested nd Worked Fine nd IMEI also fine Firmware Download Here Android 4.2.2 Mirror Link Here Login vit sammobile Acc Odin Flasher Note:if all language not available aftr flash simply root yur device install language enabler frm here nd enable all languages reboot device Also yu can install all language manually via wifi Goto settings /Language input CSC flashable Language Pack vil be added Soon Result Credits to : allumts Odin flash Log Code: Added!! Enter CS for MD5.. Check MD5.. Do not unplug the cable.. Please wait.. I9200ZTUCNG1_I9200ZZTCNG1_I9200ZTUCNG1_HOME.tar.md 5 is valid. Checking MD5 finished Sucessfully.. Leave CS.. Odin v.3 engine (ID:18).. File analysis.. SetupConnection.. Initialzation.. Get PIT for mapping.. Firmware update start.. SingleDownload. sbl1.mbn NAND Write Start!! sbl2.mbn sbl3.mbn rpm.mbn aboot.mbn tz.mbn boot.img recovery.img system.img.ext4 NON-HLOS.bin cache.img.ext4 hidden.img.ext4 RQT_CLOSE !! RES OK !! Remain Port .... 0 DON'T SAY THANKSJUST PRESS BUTTON BUTTON Last edited by jamesjerss; 03-08-2015 at 08:10. |
The Following 22 Users Say Thank You to jamesjerss For This Useful Post: |
11-28-2014, 14:58 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: ***DUBAI*** Age: 38
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | bro Tach Workng But Imei Galaxy Mega I9200 imei 0/01 help me ------------------------------------- |
The Following User Says Thank You to I_PHONE For This Useful Post: |
11-30-2014, 15:38 | #6 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
I not have select "Autoreboot" in odin It's Important, flash goes fine, have take out battery for 20/30 second then entered in Recovery Mode done Wipa/Facory reset and phone was botting w/o any issue with his Imei, all perfectament working. Read carefully all steps, my phoe was to 4.2.2 KK fw _SER p.code, repaired with 100% success BR allumts | |
01-17-2015, 20:56 | #12 (permalink) | |
BR allumts | |
01-20-2015, 10:28 | #13 (permalink) | |
For you and all, Tested 100% solution also for GALAXY MEGA LTE I9205, NO TOUCH AFTER UPDATE or BOOTLOOP HERE: guide-galaxy-mega-i9205-4-4-2-4-4-4-no-touch-bootloop-after-update-100-fix BR allumts | |
