Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Android based phones
Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones.
Old 12-18-2015, 15:01   #1 (permalink)
Member: 2483906
Thanks Meter: 2
Samsung n910c reactivation lock solution tried all boxes but failed
Sent from my SPH-L720T using Tapatalk
Old 12-18-2015, 15:13   #2 (permalink)
Member: 1025079
Thanks Meter: 311
Better if you use remote server by imei.
Old 12-18-2015, 15:54   #3 (permalink)
Member: 2117327
Thanks Meter: 48
Remote server by imei , only bypass not remove !
After factory reset lock again
Old 12-18-2015, 16:05   #4 (permalink)
Member: 1025079
Thanks Meter: 311
it does sir, you provide imei and you get id and pass to remove completed
Old 12-18-2015, 16:18   #5 (permalink)
Member: 2117327
Thanks Meter: 48
If your phone is one of the new ones like s6 or note 5 it will remove for ever but if your phone is note 4 or s5 will only bypass
Old 12-18-2015, 16:23   #6 (permalink)
Member: 2117327
Thanks Meter: 48
for note 4 and s5 username and pasword they are temporary only for bypass, after factory reset not work the same username and pasword test for me
Old 12-18-2015, 16:27   #7 (permalink)
Member: 1025079
Thanks Meter: 311
I have to do some testing then.
Old 12-19-2015, 04:42   #8 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 142
there is very private internal files that can do this. But will never be released, I think. otherwise, only method that can work is via direct emmc box, and format rpmb.
Old 12-19-2015, 18:20   #9 (permalink)
Member: 226691
Thanks Meter: 22
i have same problem any one can help
Old 12-21-2015, 01:48   #10 (permalink)
Member: 2149341
Thanks Meter: 31
Try to downgrad it to lower version and do the bypass i done several time
Page generated in 0.19758 seconds with 8 queries
