Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
02-19-2014, 09:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hyderabad INDIA
Member: 892484 Status: Offline Sonork: not using Thanks Meter: 916 | Samsung S7562 flashing guide flash file name -S7562XXALJ4_S7562OXEALH3_S7562XXLJ3_HOME.tar.md5 download from z3x support site pit file link S7562 pit file - Download - 4shared - Cheerala Srinivas S7562 flasher link S7562 flash tool - Download - 4shared - Cheerala Srinivas |
The Following 3 Users Say Thank You to chinnivardan For This Useful Post: |
03-19-2014, 13:07 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Firmware Flashing Steps: - Turn your phone off and remove Sim and Memory Card from it. - Run Odin program and check the following options: Auto Reboot - F.Reset Time - From the Extracted Firmware package you have to select files in the following order to use in Odin program: Bootloader: BOATLOADER_S7562xxxxxx_...REV02_user_low_noship.ta r.md5 PDA: CODE_S7562xxxxxx_...REV02_user_low_noship.tar.md5 PHONE: MODEM_S7562xxxxxx_...REV02_user_low_noship.tar.md5 CSC: CSC_Oxx_S7562xxxxxx_...REV02_user_low_noship.tar.m d5 - Now put the phone into Download Mode: Press Volume Down key + Home Key + Power Key. - After you see the Warning message press Volume Up Key to enter Download Mode. - Connect the phone to your PC via USB cable. - If your PC starts installing drivers then wait till it is finished. - Look at Odin's window and make sure it detects the Com port that your phone takes: If the phone's drivers is installed correctly you will see 0:[COMxx] when xx is the com port number so everything is OK. - Click Start button to let Odin downloads the selected firmware files into your phone. - During the update process it is very risky to stop the program or remove USB cable from phone so let it done without any interruption. - When the update process is done the phone will be rebooted. - If you see PASS! word at Odin's window then the update was successful. - Disconnect your phone and wait till it is fully on. - It is better to do Full Reset by this Code: *2767*3855# and let the phone rebooted. |
The Following 3 Users Say Thank You to gcceleghg For This Useful Post: |
03-19-2014, 13:08 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Tools and Drivers: - Samsung Galaxy S DUOS Firmware Package: Select and Download the wanted Firmware package for your Galaxy S DUOS and extract it. http://fileom.com/ta919nu4wdk1/S7562...4.0.4.zip.html - Odin original flasher: S7562 Galaxy S DUOS and extract it. http://www.4shared.com/rar/ZUA2B1FW/Odin307.html - USB Drivers: Download and install this drivers to let your PC recognize the device when connected and it is better to restart your PC after installing. http://fileom.com/16aqzi08ckys/USB_D....27.0.exe.html |
The Following 2 Users Say Thank You to gcceleghg For This Useful Post: |
11-16-2014, 11:16 | #7 (permalink) |
No Life Poster Join Date: Sep 2012 Location: INDIA Age: 31
Member: 1818374 Status: Offline Sonork: 100.1640346 Thanks Meter: 309 | -S7562XXALJ4_S7562OXEALH3_S7562XXLJ3_HOME.tar.md5 downoload link plz help me...........................? |
The Following User Says Thank You to mahaprobhu For This Useful Post: |
12-03-2014, 09:03 | #10 (permalink) |
Freak Poster Join Date: Oct 2006 Location: ALL IS WELL Age: 41
Member: 375663 Status: Offline Thanks Meter: 79 | http://www.dumpt.com/img/viewer.php?...fzbzbjdsh7.jpg above link u can see with tick reparation but no work |
The Following User Says Thank You to maruti82 For This Useful Post: |
12-03-2014, 09:10 | #11 (permalink) |
Member: 375663 Status: Offline Thanks Meter: 79 | http://www.dumpt.com/img/viewer.php?...uj2fxm4nsi.jpg 2nd without repartiont but no one work plz uplode u r full one pack. file |
01-30-2015, 05:57 | #12 (permalink) |
Insane Poster Join Date: Dec 2011 Location: Nanded Age: 39
Member: 1707613 Status: Offline Thanks Meter: 11 | karbonn a1 plus hard reset Power On Handset and connect to pc or laptop Download Android Tool and Drivers Install both drivers "SCI android drivers" and "ADB Android Drivers" Now open tool and press "5" and hit Enter Key to wipe data / factory reset. after format handset restart automatic |
