Tab A SM-T285 FRP Lock Need Help As the title states, I'm having issues getting around the FRP lock on a Galaxy Tab A SM-T285. Obviously don't know the google account and password. Have tried flashing a custom ROM, but FRP lock blocks the binary. I flashed a combination ROM using ODIN and was able to access developer settings via Factory Binary, but there was no option to 'Enable OEM Unlock', even after accessing Developer Settings by clicking on the relevant tab 7 times. I can install .apk's on the device using the command module in adb toolkit, but none of the 'bypass FRP' apk's I've tried seem to work, unfortunately. Any ideas what I could try to bypass, or remove the FRP lock, or maybe enable OEM unlocking via some other means? Perhaps there's a direct line of code I can use via abd? I have root access via Kingroot and I have FileExplorer and Chrome (with full internet access) at my disposal. The tablet belongs to a family member who locked themselves out. If I were being paid by the hour, I'd already have spent more than the darned thing is worth, but it's a matter of personal pride at this point. Thanks! |
http://forum.gsmhosting.com/vbb/f777...-done-2228841/ |
Appreciate the reply. |
From there it was just a case of installing a file manager and running the rootjunky frp bypass .apk, then registering a new account on the phone. Many thanks, the workaround is still valid as long as you can access an old, but still working app store download link from the Wayback Machine archive of samsungapps dot com - from around June of 2016 :D |
Press thanks bottom.. |
Already found a fix thanks to a slightly updated version of watari31's workaround. See above for details. |
HERE IS THE GOOGLE FRP SOLUTION SELECT T817P MODEL ON Z3X THEN DO RESET FRP/REACT/EE IT WILL REMOVE FRP ON T285 TAB I TESTED IT MY SELF Operation: Reset FRP/React/EE [ 6/21/2017 1:28:00 PM ] Selected model: SM-T817P [ 6/21/2017 1:28:00 PM ] Software version: 28.1 [ 6/21/2017 1:28:00 PM ] [ 6/21/2017 1:28:00 PM ] Searching Samsung USB Flash interface... COM49 detected [ 6/21/2017 1:28:00 PM ] Setup connection... Ok [ 6/21/2017 1:28:00 PM ] Reading PIT from phone... Ok [ 6/21/2017 1:28:00 PM ] Searching FRP lock... Ok [ 6/21/2017 1:28:00 PM ] Erasing FRP lock... Ok [ 6/21/2017 1:28:00 PM ] Reset done [ 6/21/2017 1:28:00 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' [ 6/21/2017 1:28:00 PM ] |
this method works Quote:
Still works thanks Quote:
Operation: Reset FRP/React/EE Selected model: SM-T817P Software version: 37.0 Searching Samsung USB Flash interface... COM8 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.37.0 |
