Samsung Android based phones Discussion and all of your questions relating to the Samsung Android based phones. |
09-16-2017, 00:01 | #1 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2758038 Status: Offline Thanks Meter: 1 | Tab A SM-T285 FRP Lock Need Help Obviously don't know the google account and password. Have tried flashing a custom ROM, but FRP lock blocks the binary. I flashed a combination ROM using ODIN and was able to access developer settings via Factory Binary, but there was no option to 'Enable OEM Unlock', even after accessing Developer Settings by clicking on the relevant tab 7 times. I can install .apk's on the device using the command module in adb toolkit, but none of the 'bypass FRP' apk's I've tried seem to work, unfortunately. Any ideas what I could try to bypass, or remove the FRP lock, or maybe enable OEM unlocking via some other means? Perhaps there's a direct line of code I can use via abd? I have root access via Kingroot and I have FileExplorer and Chrome (with full internet access) at my disposal. The tablet belongs to a family member who locked themselves out. If I were being paid by the hour, I'd already have spent more than the darned thing is worth, but it's a matter of personal pride at this point. Thanks! |
09-17-2017, 03:27 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | Quote:
http://forum.gsmhosting.com/vbb/f777...-done-2228841/ | |
The Following User Says Thank You to watari31 For This Useful Post: |
09-17-2017, 06:23 | #3 (permalink) |
Member: 2758038 Status: Offline Thanks Meter: 1 | Thanks bro, I tried it but you can no longer download apps from the Samsung website Flashed the 4 files and got access to the internet via the dialler as per your method, but can't get any further as Samsung have made it impossible to download Apps, meaning no access to the bypass apk. Appreciate the reply. |
09-17-2017, 22:08 | #4 (permalink) |
Member: 2758038 Status: Offline Thanks Meter: 1 | UPDATE: I followed your method up until accessing the Samsung Store via the tablet's browser and then because they've removed access to it via the web I used the Wayback Machine to search out the old Samsung apps website you put in your walkthrough. Couldn't get to that particular site, but I managed to find an old Spanish one which still had download links. I emailed the links to my gmail account and by signing into gmail in my tablet's browser and opening the links I was able to access the Samsung app store on the tablet. From there it was just a case of installing a file manager and running the rootjunky frp bypass .apk, then registering a new account on the phone. Many thanks, the workaround is still valid as long as you can access an old, but still working app store download link from the Wayback Machine archive of samsungapps dot com - from around June of 2016 |
09-18-2017, 18:55 | #5 (permalink) | |
Banned Join Date: Jun 2017 Location: India
Member: 2732044 Status: Offline Thanks Meter: 216 | Quote:
Press thanks bottom.. | |
The Following User Says Thank You to gadgets doctor For This Useful Post: |
09-19-2017, 01:13 | #6 (permalink) | |
Member: 2758038 Status: Offline Thanks Meter: 1 | Quote:
Already found a fix thanks to a slightly updated version of watari31's workaround. See above for details. | |
09-23-2017, 13:22 | #7 (permalink) |
Member: 2732044 Status: Offline Thanks Meter: 216 | HERE IS THE GOOGLE FRP SOLUTION SELECT T817P MODEL ON Z3X THEN DO RESET FRP/REACT/EE IT WILL REMOVE FRP ON T285 TAB I TESTED IT MY SELF Operation: Reset FRP/React/EE [ 6/21/2017 1:28:00 PM ] Selected model: SM-T817P [ 6/21/2017 1:28:00 PM ] Software version: 28.1 [ 6/21/2017 1:28:00 PM ] [ 6/21/2017 1:28:00 PM ] Searching Samsung USB Flash interface... COM49 detected [ 6/21/2017 1:28:00 PM ] Setup connection... Ok [ 6/21/2017 1:28:00 PM ] Reading PIT from phone... Ok [ 6/21/2017 1:28:00 PM ] Searching FRP lock... Ok [ 6/21/2017 1:28:00 PM ] Erasing FRP lock... Ok [ 6/21/2017 1:28:00 PM ] Reset done [ 6/21/2017 1:28:00 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' [ 6/21/2017 1:28:00 PM ] |
The Following 3 Users Say Thank You to gadgets doctor For This Useful Post: |
06-28-2019, 13:44 | #8 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | this method works Quote:
10-03-2019, 19:16 | #9 (permalink) | |
No Life Poster Join Date: Feb 2016 Location: BA
Member: 2531176 Status: Offline Thanks Meter: 225 | Still works thanks Quote:
Operation: Reset FRP/React/EE Selected model: SM-T817P Software version: 37.0 Searching Samsung USB Flash interface... COM8 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.37.0 | |
