Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 11-06-2015, 13:04   #61 (permalink)
Member: 683579
Thanks Meter: 225
Originally Posted by allumts View Post
Here "Mega Link" for Last Windows version of 13/10/2015
"flashtool-0.9.19.8-windows.exe"
- Install this Full Setup, (for Windows)
- Then replace "x10flasher.jar" with "0.9.19.10 patch"
- Download Patch for Windows from here:
"0.9.19.10 patch"
NOTE:
Here Full Setup and Patch for "Linux" and "Mac" SO:
Latest release flashtool (0.9.19.10)
allumts
i triad to this error anybody help ...
after patch replace same here
Old 11-06-2015, 19:39   #62 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Read Carefully what Folder must need of DELETE, is wrote very clear, not find directory becouse is busy from other Same folder.
allumts
Old 02-11-2016, 20:20   #63 (permalink)
Ayyub Razaa's Avatar
Member: 2509195
Thanks Meter: 51
How to use - Then replace "x10flasher.jar" with "0.9.19.10 patch"
Meens
Old 02-11-2016, 20:21   #64 (permalink)
Member: 2509195
Thanks Meter: 51
Full ditel - Then replace "x10flasher.jar" with "0.9.19.10 patch"
Step by setp pls
Old 02-12-2016, 00:57   #65 (permalink)
allumts's Avatar
Member: 1564612
Just translate with "Google Traductor" only this word: "replace" and will see that understand.
allumts
Old 02-18-2016, 10:28   #66 (permalink)
KAS HIF's Avatar
Member: 2511027
Sonork: 100.1662953
Thanks Meter: 1,113
upload other link
Windows Edition : v0.9.12.1 – MD5 : F799137347A9B24F87D3358A967E861A
Old 02-18-2016, 11:25   #67 (permalink)
allumts's Avatar
Member: 1564612
It's Obsolete and if want this version Ceck in this thread Obsolete v0.9.12.1
allumts
Old 02-18-2016, 12:11   #68 (permalink)
Akshayhackman's Avatar
Member: 2524325
Sonork: 100.1671897
Thanks Meter: 179
When you open flash tool after delete firmware folder from flash tool folder and click ok you get start your flash tool
Sent from my CP8298_I00 using Tapatalk
Old 02-18-2016, 15:26   #69 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 90
while flashing always shows this error whats wrong does i am doing please suggest me
Flashing finished.
18/042/2016 19:42:54 - INFO - Please unplug and start your phone
18/042/2016 19:42:54 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
Old 03-08-2016, 10:57   #70 (permalink)
Member: 1410464
Sonork: soos
Thanks Meter: 3
guys help with the right download link
Old 03-14-2016, 07:18   #71 (permalink)
Member: 1612293
Sonork: 100.1623024
Thanks Meter: 7
link is note working
4shared.com - free file sharing and storage
Old 03-14-2016, 10:49   #72 (permalink)
allumts's Avatar
Member: 1564612
Flashing finished.
Have you answer very clear here:
A) From Setting>Security>ceck "Unknown source"
B) From Setting, (depend of model), go in "info Phone"> Press on BUILD version since see "Now you are Developer">turn Back in Developer then "Enable Usb Debugging"
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 03-14-2016, 11:07   #73 (permalink)
allumts's Avatar
Member: 1564612
"0.9.19.10 patch"
NOTE:
0.9.19.0 was valid for ZL,Z1,Z2,Z3,Z3c,Z3+/Z4,Z4Tablet,E4,E4G,M2,M4 because of new FSC feature added.
0.9.19.10 still has fsc feature and this last one will be used if fsc is found but in all other cases, it will behave as 0.9.18. So this release is now compatible with all devices.
To apply the 0.9.19.10 patch, you must be on 0.9.19.2, 0.9.19.3, 0.9.19.4, 0.9.19.5, 0.9.19.6, 0.9.19.7, 0.9.19.8 or 0.9.19.9 and replace x10flasher.jar with the one from the patch.
USE ONLY THISBUTTON IN DOWN RIGHT CORNER
allumts
The Following 3 Users Say Thank You to allumts For This Useful Post:
Old 04-19-2016, 11:52   #74 (permalink)
Member: 1909558
Thanks Meter: 29
xperia tool v0.9.20.0
all sony xperia flash tool update tool
update link here::https://docs.google.com/uc?id=0B66Lx...xport=download
gsm.hridoy
The Following 3 Users Say Thank You to gsm.hridoy For This Useful Post:
Old 05-04-2016, 13:30   #75 (permalink)
Member: 1276750
Downloads - Flashtool
Latest release (0.9.21.0)
Page generated in 0.20362 seconds with 9 queries
