Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
02-19-2014, 08:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | [GUIDE] Z Ultra and Z1 HARD BRICK RECOVERY HARD BRICK MEANS NO FLASHMODE AND NO FASTBOOT. IN ORDER TO PROCEED DISASSEMBLY OF YOUR DEVICE IS REQUIRED. IF YOU HAVE WARRANTY,STOP READING THIS, GO THE SONY SERVICE AND PLAY STUPID. AS AFTER OPENING YOUR DEVICE, YOUR WARRANTY IS 100% VOID. I AM NOT RESPONSIBLE FOR ANY DAMAGE. YOU'VE BEEN WARNED. Let's get started. 1. Download tools.7z from attachments and pack for your device. 2. Install ggsetup-3.0.0.7.exe 3. Open the back cover of your device. 4. Find the test point (See attachments). 5. Disconnect a battery, connect a usb cable. LED RED will start to blink. 6. Using the paper clip connect your test point with the GND. I used the metal shield in the middle of the motherboard. 7. Open the device manager, you should see SEMC Flash Device. If no, you did something wrong. 8. Disconnect your phone from computer. 9, Repeat the step 5. 10.Run the s1tool and select S1 MSM8974 EMERGENCY for the phone type. 11. Press the flash button, and choice the APP file for your device. 12. Press testpoint ready and repeat the step 6. 13. Remove the testpoint and press READY, when program will ask you to do so. 14. If flash was successful, you may disconnect your phone from usb, connect your battery and try to boot.You may have to charge your battery. 15. Now you can flash your device normally using software. P.S. I was not be able to flash on windows 8 64bit, but I flashed without problems on XP. I would like to thank: the_laser for making the software. myevilface from support.setool.net for finding testpoint for c69xx. and my poor Z Ultra which I sacrificed trying to find the test point Actually I finished him when I wanted to fix audio jack. Was to happy that my device is fixed and damaged the screen connector Orignal Post Here Last edited by Faheem Anjum; 02-19-2014 at 08:20. |
The Following 25 Users Say Thank You to Faheem Anjum For This Useful Post: |
02-22-2014, 08:15 | #2 (permalink) |
Insane Poster Join Date: Sep 2007 Location: Nepal
Member: 594086 Status: Offline Thanks Meter: 9 | PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:375 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1-------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 CHIPSET NOT SUPPORTED Elapsed:29 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1----------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... help me z1 c6902 |
02-22-2014, 17:02 | #3 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2134028 Status: Offline Sonork: www.sonork.com Thanks Meter: 2 | PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:375 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1-------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 CHIPSET NOT SUPPORTED Elapsed:29 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1----------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... help me z1 c6902 |
02-23-2014, 10:04 | #4 (permalink) |
Member: 2134028 Status: Offline Sonork: www.sonork.com Thanks Meter: 2 | Please solution Please solution PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:375 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1-------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 CHIPSET NOT SUPPORTED Elapsed:29 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1----------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... help me z1 c6902 |
02-25-2014, 18:14 | #5 (permalink) |
Freak Poster Join Date: Aug 2012 Location: iran
Member: 1802554 Status: Offline Sonork: 100.1621226 Thanks Meter: 117 | hi i laso have this problem can enyone help me? Please solution PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:375 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1-------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 CHIPSET NOT SUPPORTED Elapsed:29 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1----------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... help me z1 c6902 |
02-28-2014, 22:59 | #7 (permalink) |
Crazy Poster Join Date: Jun 2008 Location: Bolivia,cochabamba Age: 49
Member: 793990 Status: Offline Thanks Meter: 18 | hi i laso have this problem can enyone help me? Please solution PROCEDURE STOPPED BY USER supported phone was not detected Elapsed:375 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1-------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 CHIPSET NOT SUPPORTED Elapsed:29 secs. SELECT FIRMWARE PACKAGES YOU CAN SELECT SEVERAL PACKAGES WITH CTRL BUTTON CHECKING PACKAGES ... DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE will use Sahara protocol ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PROCESSING ... SERIAL NUMBER : 1----------- HARDWARE ID 04000100E1207B00 NOT SUPPORTED HARDWARE ID : 04000100E1207B00 HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 Emergency loader uploaded ... I have the same problem as I resolve please |
03-01-2014, 21:10 | #10 (permalink) |
No Life Poster Join Date: Jun 2003 Location: EGYPT Age: 44
Member: 31027 Status: Offline Thanks Meter: 179 | C6902 25/02/2014 07:08:37 م PROCESSING ... 25/02/2014 07:08:37 م SERIAL NUMBER :XXXXXXX 25/02/2014 07:08:37 م HARDWARE ID 04000100E1207B00 NOT SUPPORTED 25/02/2014 07:08:37 م HARDWARE ID : 04000100E1207B00 25/02/2014 07:08:37 م HASH :49109A8016C239CD8F76540FE4D5138C87B2297E49C6B30EC 31852330BDDB177 25/02/2014 07:08:37 م Emergency loader uploaded ... 25/02/2014 07:10:38 م PROCEDURE STOPPED BY USER 25/02/2014 07:10:38 م Elapsed:158 secs. |
03-03-2014, 21:07 | #12 (permalink) | |
Member: 1802554 Status: Offline Sonork: 100.1621226 Thanks Meter: 117 | Quote:
for fix the Emergency loader uploaded ... it is better use xp windows | |
The Following User Says Thank You to IMANI MOHAMMAD For This Useful Post: |
03-06-2014, 23:49 | #13 (permalink) | ||
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
" "HARDWARE ID 04000100E1207B00 NOT SUPPORTED"" Mean Hardware is NOT Support,.... Becuase Phone have a 2 different CPU,,.... S1 Tool can repair only MSM8974 if you have C6902 with MSM8274...you have this error..." "HARDWARE ID 04000100E1207B00 NOT SUPPORTED"" | ||
The Following 4 Users Say Thank You to BABAK NURI For This Useful Post: |
