Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 02-13-2013, 15:34   #1 (permalink)
Member: 1847933
Thanks Meter: 14
Arrow How to hard reset Sony-Xperia-Neo-L-MT25i
Old 02-13-2013, 21:22   #2 (permalink)
Member: 1882718
Thanks Meter: 6
Download plasma tool from the sticky, find any firmware for your phone.
For example this one:
https://rapidshare.com/files/2254894...1246-9107_.ftf
Open the firmware with PlasmaSTool and tip userdata.sin and cache.sin only, no need full flash.
Connect phone in flash mode and click Flash.
I did it to my phones, works perfect. It will also delete all user data and clear cache, so the phone will be like new (empty).
Old 02-16-2013, 18:44   #3 (permalink)
Member: 1883363
Thanks Meter: 7
Old 02-16-2013, 18:50   #4 (permalink)
Member: 545722
Sonork: 100.1619680
Thanks Meter: 322
click onlyflash button.
Old 07-30-2013, 06:45   #5 (permalink)
Member: 1149197
Sonork: prateet
Thanks Meter: 43
Sony Experia MT25i Hard Reset Or Pattern Lock Try This Sony Experia MT25i Hard Reset Or Pattern Lock Solution ~ *********.com
The Following 2 Users Say Thank You to prateet For This Useful Post:
Old 08-03-2013, 10:56   #6 (permalink)
Member: 564102
Thanks Meter: 8
sony mt25i hard reset
on mobile phone and click on emergency call
then type code *#*#7378423#*#*
click on customiztion setting and then reset customization
after reboot set all reset done
The Following 5 Users Say Thank You to DALVINDER For This Useful Post:
Old 05-03-2014, 13:38   #7 (permalink)
Member: 1985308
Thanks Meter: 7
IT WORKS
THANKS IN ADVANCE
The Following User Says Thank You to LIONSON For This Useful Post:
Old 03-20-2015, 13:04   #8 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Sony Xperia mt25i falshing problem solve.........................
Old 03-20-2015, 13:31   #9 (permalink)
Member: 2317848
Resetting the Xperia NEO MT15i phone
Resetting the phone
You can reset your phone to its original settings, with or without deleting all of your personal data. It is possible to reset the phone to the state it was in before you first turned it on. But before you perform a reset, make sure to back up any important data saved on your phone.
To reset the phone
1. From your Home screen, tap Application icon (center icon bottom of the screen).
2. Find and tap Settings > Privacy.
3. Tap Factory data reset.
4. To erase not only internal storage but also other user data such as pictures and music, mark the Erase SD card checkbox.
5. Tap Reset phone.
6. To confirm, tap Erase everything.
Old 10-24-2015, 10:48   #10 (permalink)
.::mac::.'s Avatar
Member: 2457138
Sonork: 100.1663407
Thanks Meter: 49
my set is restart problem,anyone hard reset key solution?
Old 12-02-2021, 07:15   #11 (permalink)
Member: 2803352
Thanks Meter: 77
Arrow
Sony Mobiles Reset Methood
1 : Click On Emergency Call
2 : Type Code #*#7378423#*#
3 : Click On Customization Settings
4 : Select Reset Customization
5 : Click On Reset Customization And Reboot
Done 🙂
The Following User Says Thank You to faisal naeem For This Useful Post:
Page generated in 0.17481 seconds with 8 queries
