Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
12-14-2013, 07:19 | #2 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: chinnasalem tamilnadu india
Member: 1849338 Status: Offline Sonork: 100.1646373 Thanks Meter: 89 | Quote:
1.When you see ((mobile show google lock)) Or ((pattern)) Or ... click on emergency call 2.Type this code : *#*#7378423#*#* 3.After type you see *service info *service setting *service texts *customization setting 4.select customization setting 5.Select reset customization 6.In the last Click on Reset Customization and reboot After reboot hard reset is complete !!!!! --------------------------------------- I test this way on : St15 - St18 - Sk17 - Lt15 - Lt18 - Mt25 - St17 - St21 - St25 - lt26 - Mt11 - St26 - And ....... --------------------------------- If this way not work : If this way not work on your phone you shoud flash it .(flash with setool Or Flashtool Or Update service Or EMMA | |
12-14-2013, 07:20 | #3 (permalink) |
Member: 1849338 Status: Offline Sonork: 100.1646373 Thanks Meter: 89 | In the beta version of the flash tool for Xperia™ devices, only a limited number of device models and software versions are supported. In most cases, there are several variants of a model, and normally we only support the international variant. Check the model number in the list below to make sure your variant is supported. Please note that when you connect your phone to the computer to flash the phone, it must be turned off and you must hold the flash key listed below. Flash keys vary between models. Supported phones and flash key mappings Xperia Tablet Z (SGP321 and SGP311) – volume down Xperia go (ST27i) – back Xperia neo V (MT11i) – volume down Xperia ray (ST18i) – volume down Xperia P (LT22i) – volume down Xperia ZL (C6503) – volume down Xperia Z (C6603) – volume down Xperia PLAY (R800i) – back Xperia E dual (C1605)– volume down Xperia E (C1505) – volume down Xperia T (LT30p) – volume down Xperia S (LT26i) – volume down Xperia arc (LT15i) – back Xperia arc S (LT18i) – back. |
12-14-2013, 14:33 | #4 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: MOROCCO
Member: 1679440 Status: Offline Thanks Meter: 79 | Quote:
how to flash SONY XPERIA Z C6602 plz | |
12-09-2015, 22:23 | #9 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1843412 Status: Offline Sonork: joliedupry Thanks Meter: 0 | How to Factory reset SONY XPERIA Z (C6603) on password lock Please i kindly need your help on how to hands factory reset SONY XPERIA Z (C6603) without a PC if there any possibility to go about this? Thanks |
