Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help |
01-25-2014, 19:21 | #1 (permalink) | |
Junior Member Join Date: Jun 2008 Location: Kish Island ,Iran
Member: 789186 Status: Offline Sonork: 100.1651352 Thanks Meter: 1 | Dead Xperia z1 C6902 we have dead xperia Z1 C6902 after flashing is Dead when plug to computer just red light on and dont be green -the battery is full Se tools Log : Quote:
tanks | |
01-26-2014, 13:35 | #2 (permalink) |
Major Poster Join Date: Mar 2007
Member: 467886 Status: Offline Thanks Meter: 6 | i to have same problem. pls help to fix it. SIGNED MODE (USING SERVER) CFG:101100000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&48f32ea&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: < ... FAILED TO SETUP PHONE Elapsed: 10 secs. Last edited by zubairattari; 01-26-2014 at 13:41. |
02-09-2014, 15:11 | #5 (permalink) |
Insane Poster Join Date: Feb 2014 Location: Kanpur
Member: 2120469 Status: Offline Sonork: 100.1653238 Thanks Meter: 47 | chek phone ask driver point and give location and flash with se tool and select file letest version i think your problem solved |
The Following User Says Thank You to GOPAL007 For This Useful Post: |
09-25-2014, 16:53 | #7 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Athens
Member: 1020935 Status: Offline Sonork: 100.1604039 Thanks Meter: 28 | Hi I have same problem with C6833 SONY XPERIA Z ULTRA i did flash and flashing phon just blink red light on top and whe i try to flash again with setool i get this error PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: [\\?\USB#Vid_0fce&Pid_d19a#5&1398a1f1&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}] open error: ... FAILED TO SETUP PHONE Elapsed: 16 secs. |
09-25-2014, 23:29 | #8 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Download official correct firmware using tis tool d convert the file as ftf den flash using flash tool . http://forum.gsmhosting.com/vbb/f778...luded-1861399/ check my post red light black display fixed by flashing using flashtool success report posted by a member |
09-26-2014, 14:18 | #9 (permalink) |
Member: 1020935 Status: Offline Sonork: 100.1604039 Thanks Meter: 28 | Hi jamesjerss Thanks for Reply i did try as you posted but i thing my phone in not connecting as flash mode 26/003/2014 16:03:26 - INFO - <- This level is successfully initialized 26/003/2014 16:03:26 - INFO - Flashtool Version 0.9.13.0 built on 2013-06-04 22:50:00 26/003/2014 16:03:31 - INFO - Device disconnected 26/003/2014 16:03:38 - INFO - Selected Xperia Z Ultra C6833 / 1276-0119_14.4.A.0.108 / 3 UK 26/003/2014 16:03:38 - INFO - Preparing files for flashing 26/005/2014 16:05:59 - INFO - Please connect your device into flashmode. 26/008/2014 16:08:20 - INFO - Device connected with USB debugging off 26/008/2014 16:08:20 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/008/2014 16:08:37 - INFO - Device disconnected 26/008/2014 16:08:38 - INFO - Device connected with USB debugging off 26/008/2014 16:08:38 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:05 - INFO - Device disconnected 26/009/2014 16:09:11 - INFO - Device connected with USB debugging off 26/009/2014 16:09:11 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:16 - INFO - Device disconnected 26/009/2014 16:09:17 - INFO - Device connected with USB debugging off 26/009/2014 16:09:17 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:25 - INFO - Device disconnected 26/009/2014 16:09:29 - INFO - Device connected with USB debugging off 26/009/2014 16:09:29 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/009/2014 16:09:53 - INFO - Device disconnected 26/010/2014 16:10:00 - INFO - Device connected with USB debugging off 26/010/2014 16:10:00 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/010/2014 16:10:03 - INFO - Device disconnected 26/010/2014 16:10:07 - INFO - Device connected with USB debugging off 26/010/2014 16:10:07 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/010/2014 16:10:42 - INFO - Device disconnected 26/010/2014 16:10:50 - INFO - Device connected with USB debugging off 26/010/2014 16:10:50 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/010/2014 16:10:53 - INFO - Device disconnected 26/010/2014 16:10:54 - INFO - Device connected with USB debugging off 26/010/2014 16:10:54 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:03 - INFO - Device disconnected 26/011/2014 16:11:08 - INFO - Device connected with USB debugging off 26/011/2014 16:11:08 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:14 - INFO - Device disconnected 26/011/2014 16:11:15 - INFO - Device connected with USB debugging off 26/011/2014 16:11:15 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:21 - INFO - Device disconnected 26/011/2014 16:11:24 - INFO - Device connected with USB debugging off 26/011/2014 16:11:24 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:32 - INFO - Device disconnected 26/011/2014 16:11:37 - INFO - Device connected with USB debugging off 26/011/2014 16:11:37 - INFO - For 2011 devices line, be sure you are not in MTP mode 26/011/2014 16:11:47 - INFO - Flash canceled IF any other Option you have let me know i'll try Thanks |
